Collected the GT Speed last yesterday
Picked up the 08 Speed yesterday. fantastic 400 mile drive back not a single problem. I averaged about 19.5 mpg over the 400 miles. The first 100 were cross country so I think that's not bad.
I do have a problem now though. Since today I keep getting an amber Parking brake P alarm on the dash when I start up or some times when driving. If I stop switch off, restart I get a green message telling me to press the brake peddle. It seems to be ok for a while but comes on at strange times
I forgot to say its an amber P with a / through it . and on one occasion the car felt sluggish as if the Parking brake hadn't completely disengaged.
Any one know what it means.
Frank
Frank
I know the p on the cluster effects many conti gts
Very common problem, mine does it sometimes
If you search thru threads you will read its usually a sensor
It's a common bug
I am not fixing mine untill it gets bad, it comes on once a week if that
It's a common bug
Does it matter if warning light comes up sometimes but disappears when you restart the car? I get air suspension and ABS errors sometimes when I play with the vehicle height. The message disappears if I restart the car.
Thanks, I must try the Jack mode some time just to see how it works. I read about it last night.
Had the same problem. It could be the sensor in the right (or left in your case, need VAG-COM) rear brake caliper assembly. These are cropping up on various cars and the 06 GT had that problem. Price? It was fixed under warranty and an easy, maybe 1 hour factory fix. Not sure the part cost, all paperwork to the previous car went with the... Oh wait, I might have it here!
part 3W0907801E CM brake actuator $252.
I haven't got my diagnostic tester as yet so I phoned Glasgow Bentley, they are picking the car up on Wednesday as they suspect a poor performing park brake motor or sensor. .
I will post the outcome when its fixed
It wont affect anything other than e-brake. Alas. the damn big yellow /P covers the center dash, which means the GPS directions capability/etc details on the center dash does not allow for various screens to operate correctly. More annoying than anything else and easy to fix.
Stuck until you re-cycle the system. Forget if it is just an on-off of the car, or if you have the leave and lock the car, then unlock and restart so the electronics 'reset' per se. For me, I 'live off' GPS so it was a situation that was fixed very fast.
Bentley Glasgow picked up car fixed fault and deliver car back next day with new sensor and actuation motor. cost £379 including labour and 20%Vat.
I cleared a few old outstanding issues caused by a flat battery 10k miles ago while I was at it. I also found an intermittent Terminal 30 defect which Bentley also put right for free and I found the steering angle sensor required a full calibration as it was in an estimated state, they did a full calibration for free as well . Well done Bentley Glasgow.
