Car stalling right after startup help please
Old 09-05-2013 | 09:26 AM
robermj1's Avatar
robermj1 is infamous around these parts
I have a 2008 Bentley flying spur that will start and stay running for all of 2 seconds, I have run DTC codes with vagcom and came back with:
VCDS Version: Release 11.11.6
Data version: 20121223
3b
Thursday,05,September,2013,08:47:12:17346
Chassis Type: 6N0
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1F 28 34 36 37 38
42 46 47 52 53 62 65 66 68 71 72 76 77
Mileage: 22390km/13912miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 1010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1F-Sat. Tuner -- Status: Sporadic communication error 1000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 1010
65-Tire Pressure -- Status: Malfunction 1010
66-Seat, Rear -- Status: Malfunction 1010
68-Wiper Electr. -- Status: Malfunction 1010
71-Battery Charger -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 G HW: 3D0 909 137 G
Component: 7E Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0I7866057
Coding: 0405741
Shop #: WSC 04940 001 00001
VCID: 2B5F3AB38E46F240A59
Part No: XXXXXXXXXXX
Component: ELV XXXX
7 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 14
Reset counter: 53
Mileage: 1048575 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 53
Mileage: 1048575 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 53
Mileage: 1048575 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
00458 - Control Module for Battery Monitoring (J367)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 53
Mileage: 1048575 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 53
Mileage: 1048575 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 13
Mileage: 1048575 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
00087 - Terminal 30 for Starting Relevant Consumers
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 53
Mileage: 1048575 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:14
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Address 11: Engine II
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No SW: 3W0 920 841 R HW: 3W0 920 841 R
Component: J285 KOMBI-INST. 1824
Revision: K0H10V30
Coding: 0007201
Shop #: WSC 03066 104 72594
VCID: 448D710F07D81D38443
14 Faults Found:
00459 - Control Module for Display and Input; Front (J523)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 06:08:43
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.02
Time: 00:56:34
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:21:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:21:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:21:35
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:39:05
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:17
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:17
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:20
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3W0 920 841 R
Component: J533 GW-K-CAN TP20 1824
Coding: DFF8FF7E17071702
VCID: F0E56DDFE3E0519850B
19 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 06:08:43
00462 - Control Module for Seat Memory; Rear (J522)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:20
01335 - Drivers Seat/Mirror Position Control Module (J543)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 06:00:48
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 06:00:48
02649 - Digital Radio Tuner
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:21:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:21:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:21:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:21:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 07:39:05
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:16
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 22396 km
Time Indication: 0
Date: 2006.01.01
Time: 09:45:20
Address 1F: Sat. Tuner
Cannot be reached
Address 28: HVAC, Rear
Cannot be reached
Address 34: Level Control
Cannot be reached
Address 36: Seat Mem. Drvr
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W5 035 456 B
Component: 12K-AUDIOVERST 0007
Shop #: WSC 00000 000 00000
VCID: 387515FF4F1049D8D8B
2 Faults Found:
002 - Lower Limit Exceeded - Intermittent
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Address 53: Parking Brake
Cannot be reached
Address 65: Tire Pressure Labels: None
Part No SW: 3W7 907 273 A HW: 3W7 907 273 A
Component: J0502 RDK 0004
Revision: 0004 004 Serial number: 00000900001143
Coding: 0000E05286FD5286FDA7DA00A7DA00
Shop #: WSC 00083 790 00000
VCID: 3E7903E76D3477E8127
1 Fault Found:
01840 - Antennas for Tire Pressure Monitoring
005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 145
Time Indication: 0
Freeze Frame:
(no units): 177.0
Address 66: Seat, Rear
Cannot be reached
Address 68: Wiper Electr.
Cannot be reached
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 E
Component: Batteriemanagement 2800
VCID: 254BCC8BE8A2C43073D
3 Faults Found:
00576 - Terminal 15
008 - Implausible Signal - Intermittent
00456 - Control Module for Access and Start Control (J518)
Address 76: Park Assist
Cannot be reached
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 AS HW: 3W0 035 385 AS
Component: rSAP Bentley 0262
Revision: 00008000 Serial number: 30800000016602
Coding: 0031000
VCID: 86092B07F5646F289A7
No fault code found.
End ---------------------------------------------------------------------
Any help would be great
Old 09-05-2013 | 09:59 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
please try spare key first,then check batteries(both).
Old 09-05-2013 | 10:01 AM
robermj1's Avatar
I have tried all keys with the same success
Old 09-05-2013 | 10:11 AM
have you checked batteries in the boot/trunk and are you getting any codes on your drivers info panel(dip).
Old 09-05-2013 | 10:14 AM
robermj1's Avatar
batteries new and fully charged, the center dash says, "multiple keys found", nothing else out of the ordinary
Old 09-05-2013 | 10:16 AM
when did this start happening what were the preceding events.
Old 09-05-2013 | 11:09 AM
robermj1's Avatar
window left open and we went on vacation, bentley in turn replaced the kessy module new keys, steering column and the 2 ecu's we then took the car home and it sat for 2 months end of aug. I replaced 2 batteries and it has not run since turns over fine cranks starts and dies within a few seconds of being on
Old 09-05-2013 | 11:42 AM
take it back to dealer and have them re-program keys to car !!
Old 09-05-2013 | 11:45 AM
robermj1's Avatar
easy as that? Nothing like going crazy over something I thought I may have done
The (dip) shows multiple keys found though?
Old 09-05-2013 | 11:47 AM
well nothing is easy,but i know you have probably done that...i believe the keys need re-programming,its not un-common..the dealer should do it for free and as goodwill .
Old 09-05-2013 | 12:10 PM
robermj1's Avatar
everything is easy with the correct tools and knowledge, thank you very much Bentleytech, I will let you know what Chuck at the Bentley dealer tells me
Old 09-06-2013 | 03:31 AM
just before you call dealer have you tried a key without the others present,but if that doesn't work,that log definitely shows a key issue,if they fitted new parts you get 3 years parts and labour which should include the tow into the place.
Old 09-06-2013 | 05:20 AM
robermj1's Avatar
Yes just tried taking other key out of the car with the same result a quick start then turns off
Old 02-16-2017 | 11:22 AM
jim2331's Avatar
jim2331 is infamous around these parts
....what was finally the resolution of "turn off" situation...did it have anything to do with new keys and a security feature...JimB San Francisco 10Speed
COBB Tuning
01-29-2022 09:42 AM
PorscheEnthusiast
11-13-2015 02:23 PM
gulf gt
08-27-2015 10:27 AM
08-21-2015 09:56 AM
Quick Reply: Car stalling right after startup help please
