Should I glue it: Loose lower front bumper trim
Old 04-01-2014 | 04:29 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
Hi all,
Yesterday, I discovered my black rubber trim went missing. As result, I installed the chrome trim I bought awhile ago.
The only issue is the chrome trim doesn't fit too snugly especially on the Passenger side.
Is there any way to make it fit better? Should I glue it? If yes, what kind of glue should I use?
ID:	354045   Click image for larger version
Old 04-06-2014 | 01:00 PM
ExoticCarDriver's Avatar
ExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really nice
I had the same issue happen to mine but my grill is black. For a quick fix, I used black zip ties around the grill and bumper pieces circled in red on the attached pic. You can't even notice it since its under the bumper. Maybe you can try a very thin clear zip tie to make it less noticeable on your chrome trim.
Old 04-06-2014 | 07:06 PM
lilo1980's Avatar
Thanks ExoticCarDriver. I've decided to order the OEM black grille for $200 . I realized the Chrome lower grill doesn't look that nice because it takes focus away from the main grille.
I will try with the black grille and see if it fits better. I will also try it tie it up in case it falls off again. Hah I don't want to lose another $200.
04-28-2022 12:38 AM
COBB Tuning
01-29-2022 09:42 AM
TrackOne
08-20-2015 12:56 PM
Vrseis
08-20-2015 07:41 AM
Nissan GTR
08-19-2015 02:11 PM
Quick Reply: Should I glue it: Loose lower front bumper trim
