CGT cabin air filter replacement
Old 03-04-2015 | 02:42 PM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
Is there a trick to removing the cabin air filters under the hood? I must be missing something very simple.
Thanks.
Paul
Old 03-05-2015 | 01:11 PM
vanslam's Avatar
vanslam has a spectacular aura aboutvanslam has a spectacular aura aboutvanslam has a spectacular aura about
Just firm grip and pull.
Old 03-05-2015 | 01:14 PM
pwc6t3's Avatar
I expected some finesse way to do it, turns out you are right, just brute force.
Thanks for the reply.
Paul
Old 09-12-2015 | 08:22 PM
Gil Thomas's Avatar
Gil Thomas is infamous around these parts
I am new to this forum and trying to identify the location of my cabin air filters. 200 Arnage Red Label. Thanks in advance.
Old 09-13-2015 | 02:38 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
on the arnage lift the hood and at each corner next to windscreen , the bulkhead in some countries you will see two phillips screws, those undone and you can lift the cabin filters out.
Old 07-17-2016 | 03:56 PM
MrVette's Avatar
MrVette is infamous around these parts
Are the 2008 GT Speed engine air filters and cabin air filters Bentley only parts or are the available aftermarket, VW or Audi?
Old 07-18-2016 | 11:00 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Cabin filters are available on eBay for around $75. Just pull off the plastic frame that holds the filters and swap 'em out
http://www.ebay.com/itm/Cabin-Air-Fi...pViI5e&vxp=mtr
Old 07-19-2016 | 03:30 PM
MrVette's Avatar
Thanks for the tip. Pulled mine out and banged them on the ground. They seem quite clean. Did the same with the engine air filters and got enough dust to indicate it was time to clean them. I noticed they have a VW emblem and part number on them. Did manage to lose one short torx screw in the process.
Old 04-29-2017 | 01:26 PM
cl600bill's Avatar
cl600bill is infamous around these parts
Reply to an old post -- thanks again for tips on automatic transmission. Regarding cabin filters on 2006 GT, where are they?
Also, can't find info on engine air filter location and how to change.
Old 04-29-2017 | 03:56 PM
MrVette's Avatar
Cabin air filters are on the underside of the hood/bonnet. Gray pleated. One on each side. They are held in place by plastic frames.
Engine air filters are under the covers on both sides of the engine. You need to remove the covers with torx screwdriver. Lift out the yellow filters and replace. Very simple.
Old 04-29-2017 | 06:27 PM
Rons GT Speed's Avatar
Rons GT Speed is infamous around these parts
You can hold the filter up to the sunlight to judge if they are plugging. You should be able to see the sunlight through the filter when clean.
Ron
Old 04-30-2017 | 05:31 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Just for info, the air cleaner lids are the ones with 6.0 Litre and Twin Turbo logos on them.
Les.
Old 04-30-2017 | 05:14 PM
cl600bill's Avatar
Any idea what number Torx screwdriver needed to remove filter lids/covers. Don't have one and need to buy. The 8 in one sets get poor reviews for quality and I'd rather buy one high quality one. Sorry to get so far into the weeds on this one. I appreciate all the insight and clarifications. I could just go to the dealer but they would automatically replace rather than inspect to see if really need replacing.
Old 05-01-2017 | 05:38 AM
ExSF's Avatar
Hi Bill.
It's a T30 Torx.
Les.
Old 05-01-2017 | 07:14 AM
Daddy C.'s Avatar
Daddy C. is a jewel in the roughDaddy C. is a jewel in the roughDaddy C. is a jewel in the rough
the cabin air filters have active charcoal in them. That 'wears out' in about one year's time. If you dont like outside-airsmell getting trough in the interior, you might want to swap them regularly with new ones.
Myself , i dont care and use them as long as they remain dust-free.
Quick Reply: CGT cabin air filter replacement
