Blocked drain holes - GT 2004
Old 04-07-2015 | 04:54 PM
will_wonka's Avatar
will_wonka is infamous around these parts
Angry Blocked drain holes - GT 2004
Well had a good search, be gentle if I missed a response
Any help appreciated on my Bentley GT 2004.
Drain holes - drains for the spoiler area - mine has the water issue which I noticed when I washed at the weekend, it was like floodmybootageddon when I finished and opted to open the boot - water went everywhere !!
I'm guessing the drains are the 2 holes on the bottom of the boot panel?? effectively 2 open rubber grommets (one each side) and one blanked off in the centre.
If they are, I got hold of some strimmer cable (thickish) and went through about 5m in length but could not see where the end was coming out - if anyone has any experience could you advise please.
I did the filler cap one, but once again could not see where it was coming out - it just ate the strimmer wire by about 3m when I stopped.
Old 04-07-2015 | 07:35 PM
Arachnophobia's Avatar
Arachnophobia is infamous around these partsArachnophobia is infamous around these parts
I had the same issue on my 2007. I just used compressed air from the top and it blew everything right out; no further problems.
Old 04-08-2015 | 11:03 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
+1 for the compressed air trick. That worked on my filler drain too. After clearing it out, I squirted some WD40 down there and haven't had a problem since.
The boot drains are the two rubber grommets you mention.
Old 04-08-2015 | 12:46 PM
will_wonka's Avatar
Thanks guys - so where are the exit and entry points for the ducts? On the boot lid I'm guessing the ones on the bottom are exit, but where is the entry 😡 squirting air I get but just curious?
Have looked under the spoiler- nothing so baffled as to how the water exits if it can't enter 😳👍
Old 04-08-2015 | 08:36 PM
ULSTRUP's Avatar
ULSTRUP is infamous around these parts
The filler cap exit drain is located behind the rear wheel close to the wheel arch aft.
Old 04-09-2015 | 06:37 PM
Do a search in this forum for "a large amount of water", there are pictures of the drains. Hope this helps.
Old 03-26-2022 | 03:48 PM
cerex's Avatar
cerex is infamous around these parts
Made a little video when I did my maintenance hope this helps others
ECS Tuning - BMW
10-01-2015 01:35 PM
ECS Tuning - BMW
10-01-2015 01:29 PM
JWrightPNH
10-01-2015 01:21 PM
ECS Tuning - VW
09-30-2015 12:21 PM
JB GT3
09-24-2015 10:01 PM
Quick Reply: Blocked drain holes - GT 2004
