Bentley wing mirrors
Old 05-06-2015 | 11:53 AM
joc44's Avatar
joc44 is infamous around these partsjoc44 is infamous around these parts
HI,
can someone tell me how to remove the underside of the wing mirrors as mine
have gone green over time and needs a good clean (GT 2004), the drives seat has a problem now, when it's reclined forward ie let someone in the back it will
not stay forward.
thanks joc
Old 05-06-2015 | 11:35 PM
ULSTRUP's Avatar
ULSTRUP is infamous around these parts
Sorry, I can't tell you how to do it but I know it's doable since they removed them from my car, polished them and replaced the seal.
costed me €120 so can't be a big job.
Old 05-07-2015 | 12:16 AM
jc_333's Avatar
jc_333 is infamous around these parts
You mean the wing mirror turn signal? Adjust mirror so its furthest looking into car then with a plastic tool prise mirror off at outer edge. Mirror is held into place by little plastic tabs. Unplug mirror heater wiring and signal housing is secured by two screws I recall. Mirror just pops back into motor with a gentle press. J
Originally Posted by ULSTRUP
Sorry, I can't tell you how to do it but I know it's doable since they removed them from my car, polished them and replaced the seal. costed me €120 so can't be a big job.
Old 05-07-2015 | 04:56 AM
joc44's Avatar
sorry maybe i wasn't clear about witch part please see my pictures.
thanks JOC
Old 05-07-2015 | 05:01 AM
jc_333's Avatar
You can remove them using method I mentioned.
I don't think the housing can be separated as I only recall bulb hole where you could clean lens with a cotton bud or similar object.
J
Originally Posted by joc44
sorry maybe i wasn't clear about witch part please see my pictures. thanks JOC
Old 05-07-2015 | 08:43 AM
joc44's Avatar
THANKS, JC 333
done it, all clean.
JOC
Old 05-07-2015 | 10:45 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
How on earth did you manage to get them that clean. I tried a while ago and had limited success. I have now decided to have them tinted a little to hide the mucky look.
Les.
Old 05-07-2015 | 08:24 PM
jc_333's Avatar
WoW..that is clean! Does the lens and housing come apart?
Just saved yourself 120euro...drinks on you. haha
J
Old 05-07-2015 | 11:09 PM
ULSTRUP's Avatar
Les.
I don't know how he did it, but my detailer told me that to clean the headlights he uses some swirl removal compound applied with 1000 sand paper and alcohol and finally wax.
great job JOC44.
Old 05-08-2015 | 06:03 AM
ExSF's Avatar
No. The green gunge is inside the lamp housing and very difficult to get at.
Lets hope we find out the secret.
Old 05-08-2015 | 07:24 AM
jc_333's Avatar
Maybe be pour a bit of bleach inside housing and gave it a good shake around?
Old 05-08-2015 | 11:20 AM
joc44's Avatar
HI ALL,
bleach, warm water,a piece wire and a power washer.
you must remove the LED's first and leave soak for as long as possible.
the n/s one is 5/6 times as bad so going to leave it soak over night, make a very very small loop in the wire around a very small piece of cloth to stop it scratching the inside,
a lot of patience and job done.
JOC
Old 05-08-2015 | 12:26 PM
joc44's Avatar
any thoughts on the drives seat
Old 05-09-2015 | 02:42 AM
ExSF's Avatar
Hi.
Thanks for the info on the light cleaning.
With regard to the seat problem, I suspect it is wear and tear on the part that holds the seatback forward.
Les.
Old 05-09-2015 | 06:26 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Great info on the light cleaning, MUCH appreciated!
Quick Reply: Bentley wing mirrors
