fuel impact shut off relay
Old 07-17-2015 | 08:46 AM
teknix999's Avatar
teknix999 is infamous around these parts
Hi does anyone have any idea if there is a fuel impact shut off relay?
If so where would I find it?
the car was running fine until it hit the ditch now the fuel pump does not make any noise yet all wiring fuses etc. seems good.
thank you in advance
Terry
Old 07-22-2015 | 10:54 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Hi.
I had a look on IETIS for you but couldn't find anything after trying various words.
I do know that on some Jaguars the cut off is inside the glove-box, so it might be worth having a root around in there or just underneath it perhaps.
Les.
Old 07-23-2015 | 01:44 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
have you tried reading the codes, with most of our cars everything is controlled by a control module so reading the faults you may well see a fault in relevant to your issue. From memory i don't believe an actual switch is fitted to continental series.
Old 07-29-2015 | 04:09 PM
teknix999's Avatar
thanks guys but seems Mr Bentley is right , as i have removed both bats and now all is good after reconnection all systems are go and starts sweet
time to start the the strip down
adnanm3
11-22-2023 02:43 AM
ModBargains
Bentley Vendor Classifieds
10-13-2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
10-13-2015 03:42 PM
ModBargains
McLaren Vendor Classifieds
10-13-2015 03:41 PM
ModBargains
10-13-2015 03:40 PM
Quick Reply: fuel impact shut off relay
