Boost pressure control valve/n75
Old 12-27-2015 | 09:27 AM
General7226's Avatar
General7226 is infamous around these parts
Does anyone no were the n75 is located on the Bentley continental gt
Old 12-28-2015 | 08:07 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Here is the location for bank 1 (passenger side rhd). See yellow highlights
Old 12-29-2015 | 12:00 AM
jc_333's Avatar
jc_333 is infamous around these parts
I know with some specific versions of the N75 valve they give extra bit of boost say 1-3psi. I swapped to a J version in my Audi and turbo response was better.
Can the same be said for the Bentley?
J
Old 12-30-2015 | 05:00 AM
Thanks for your response were exactly on the veichle is that situated it's a bit difficult to understand were that is I have the Bentley iTIes but it's not easy to understand were it is on the veichle
Old 12-30-2015 | 07:52 AM
PMS's Avatar
PMS
I have provided the schematic for N75 on bank one. Bank one is the right side of the engine as seen from the driver's perspective. You will probably need to remove the air filter assembly in order to access the N75.
Old 12-30-2015 | 08:24 AM
Hawk375's Avatar
Hawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to all
based on the schematic, it should be around here:
Old 12-31-2015 | 11:54 AM
Anyone no the part number for the n75 valve thanks..
Old 01-01-2016 | 06:15 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
give me your vin i will find the part for you
my car is flying spur 2008. I replaced it with the OEM supply Bosch with much better price
Bosch part no : 0 261 230 073
Old 09-07-2018 | 04:33 AM
Kes's Avatar
Kes
Kes is infamous around these parts
Hi, i need part numbers for n75 and n249? can anybody help?
In few days will be getting engine out to replace n249 so at same time want to replace n75 too.
Old 09-08-2018 | 09:30 AM
PMS's Avatar
PMS
N75 is C00674. N249 is C00667
Old 09-08-2018 | 02:31 PM
Kes's Avatar
Kes
Thanks, but can not find any of them online. Is this vw part number?
Old 09-08-2018 | 02:41 PM
PMS's Avatar
PMS
Sorry, I gave you the IETIS manual number from the diagram. I can't seem to source the actual Bentley part number. I'll keep trying.
UPDATE
I can't find the part numbers in the IETIS manual. However, this page from Scuderia Parts may prove to be of some help:
https://www.scuderiacarparts.com/par...123/2112/37882
Old 09-08-2018 | 03:13 PM
Kes's Avatar
Kes
I did find these on flyingspares, but i want bosch or piersburg number. I guess they are made by piesburg.
Old 11-11-2019 | 09:26 PM
Yoghurtshotgun's Avatar
Yoghurtshotgun is infamous around these parts
Did anyone get a part number for the boost control valve n75
Or can they cross ref it to another model maye be an Audi one so far can get it at a local parts store .thanks guys
Old 11-12-2019 | 01:59 AM
Kes's Avatar
Kes
Yes, i had engine out and that what i had already installed. Not sure it was replaced earlier.
Quick Reply: Boost pressure control valve/n75
