MAF Sensor Replacement
Old 05-18-2016 | 10:34 AM
onefastman1's Avatar
onefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to all
All,
I am working through a P0171 code and am going to start by replacing the MAF sensor. The new MAF and the car arrive today so it will be done shortly.
However, I am unsure which side is bank 1
Can some direct me and let me know if it is driver or passenger side?
Also, is the MAF easily accessable on these cars? I'm sure I can locate it but advice is welcomed.
Thank you and I will report back after it is done.
Old 05-19-2016 | 07:24 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
bank one (seen from the front of the car) is on your left. The MAF is very easy to access. However, best you source a copy of the IETIS service manual (available on disk) for this and other DIY work. I believe REDNOSEGT (on this forum)is offering same.
Old 06-15-2016 | 08:20 AM
Replaced the MAF and did an EVOMS tune.
The replaced MAF and reset ECU has solved my CEL (so far 1.5 tanks of fuel)!
Old 06-15-2016 | 12:09 PM
PMS's Avatar
PMS
Good news! Please let us know if the fix holds.
Old 05-12-2017 | 12:23 PM
4KB's Avatar
4KB
4KB is infamous around these parts
Message to: onefastman1
I just got the same p0171 and have purchased the MAF sensor. Ill be replacing it on bank 1 per the code reader. Any diagram or additional info you can provide that will assist me with install? Car runs fine with no hunting idle or stumbling. Thanks
Old 05-14-2017 | 07:52 AM
4KB's Avatar
4KB
Anyone have info I can use? Thanks
Old 05-14-2017 | 03:54 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
I will try to look for some info from the service manual tonight.
Old 05-14-2017 | 04:07 PM
4KB's Avatar
4KB
Thanks sir. Much appreciated. Gil
Old 05-14-2017 | 11:29 PM
lilo1980's Avatar
Hi Gil,
Here you go. Hope this helps:
http://imgur.com/a/rtuwo
Old 05-16-2017 | 06:53 PM
4KB's Avatar
4KB
Thanks again lilo1980. Will tackle job over the weekend.
artyve
04-14-2016 08:06 AM
mikble911
03-28-2016 02:47 PM
REDNOSEGT
Bentley
03-25-2016 11:07 AM
Quick Reply: MAF Sensor Replacement
