Bentley Gear stick question
Old 10-16-2017 | 06:28 AM
lp640montoya's Avatar
lp640montoya is infamous around these parts
I did not have a problem ordering i went to their site alpineperformance.com and ordered directly you can also call them 754-204-2100 this is the link to their site
http://www.alpineperformance.com/ben...nt?search=dust
Old 10-24-2017 | 08:16 PM
JyB's Avatar
JyB
JyB is infamous around these parts
Hi,
Thanks for the information, I have now received the dust cover ... Trying now to understand how to change it ... Did any one take pics of the procedure?
Thanks and have a great day
JY
Old 10-25-2017 | 08:22 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
check out this previous post: https://www.6speedonline.com/forums/...ing-cover.html. It will show you the various elements. Note: also check to see how to remove the shift ****. https://www.6speedonline.com/forums/...s-already.html
Old 10-25-2017 | 07:07 PM
JyB's Avatar
JyB
Thank you for the links. Before starting on it, I would have just a few questions, can you let me know the following:
- I guess I can change it while the whole unit is in place, I do not need to remove it, correct?
- How is the silver round cover attached to the unit, do I just pull it up and it comes out?
- I can see how the black piece with the R, N, D, S buttons is attached, it should not be an issue to pull it out.
Do I need to remove more parts or is the dust cover just there?
Thank you very much and have a great day ahead
JY
Old 10-26-2017 | 08:57 AM
PMS's Avatar
PMS
You need to do quite a bit of disassembly in order to access the cover. The best advice I can provide is to acquire the IETIS service manual. First, read this thread on the forum:
https://www.6speedonline.com/forums/...is-system.html
2nd. You can order this manual on-line from a number of companies. The price is usually under $100.00. The manual will help you with ANY DIY project you wish to tackle. If you can't source the manual, PM me for further insights.
Peter
Old 05-16-2023 | 12:21 AM
Ricardo10X's Avatar
Ricardo10X is a name known to allRicardo10X is a name known to allRicardo10X is a name known to allRicardo10X is a name known to allRicardo10X is a name known to allRicardo10X is a name known to all
Gear shift sensor not working
Hello everyone
I know this is an old thread so hopefully someone will see my comment.
I have a 2007 Arnage t and the the shifter works perfectly on automatic and sport, however the gear display in the dashboard, is fully lighted up with all gears showing illuminated.
The gears cannot be changed manually.
The dust cover is broken.
would anyone know if the fix is to change the dust cover ?
thanks
Old 05-16-2023 | 05:44 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
most probable symptom for the gears all light is the magnet issue - cover replacement should fix it
if not work then the electronic plate has to be replaced
start with easiest/ cheapest thing
but no pissibility to switch gears in manual mode may be more complicated problem and your gearbox is in emergency mode.
any errors in vcds? do the diagnosis prior dissasembling anything.
Old 05-16-2023 | 12:24 PM
Ricardo10X's Avatar
Helo Sazam
I have not tested with vcds but there are no error messages on the dash info center.
Do you know if I can use OBD-II to test?
On automatic mode, the car shifts fine, if while driving I pull the gear shifter to S (sport) the gearbox changes to the lower gear so I it is operating fine.
Would you know the parts number of name of the part that you suggest replacing (magnet issue - cover replacement) I am not sure what to look for and purchase.
Thank you so very much for your help on this matter
Ricardo
Old 05-16-2023 | 11:10 PM
BruceR's Avatar
BruceR is infamous around these parts
I don't know if this will fit your model but I'm guessing it would. I had the same problem after the dust cover broke on my old '09 GT. This fixed it.
Amazon Amazon
Old 05-16-2023 | 11:25 PM
Ricardo10X's Avatar
https://www.amazon.com/dp/B09HKK1VT5...v_ov_lig_dp_it
Just ordered it, Ill let you know how it goes
THANK YOU SO MUCH
Old 05-17-2023 | 08:48 AM
BruceR's Avatar
You're welcome!
See this thread too:
https://www.6speedonline.com/forums/...one-wants.html
British
Bentley
03-28-2019 09:33 AM
JGhuman
Bentley
11-04-2018 09:14 PM
cduluk1
Bentley
05-03-2016 07:38 AM
Beer brewer
02-14-2013 02:13 PM
ccwboy
Bentley
09-22-2011 09:45 PM
Quick Reply: Bentley Gear stick question
