Bentley GT 2013 and + and Samsung S7 compatibility
As i recall, rSAP does not work with modern cell phones. It is an old communication standard that was pretty much phased out many years ago. I believe Bluetooth should work with the 2013. rSAP might work with come 'hacks' yet in the end Bluetooth is the more modern standard nowadays. Android phased out rSAP support, as I recall, after version 3 (we're now on version 6, aka Marshmallow).
On Bentley motors website under the "ownership" tab there is both Bluetooth and music player compatibility guides. You will find some phones are compatible but only with a certain software level. http://bluetooth.bentleymotors.com/
Samsung has supported RSAP for the past 3 generations of Galaxy phones, but as far as I know most idiot providers in US (Verizon for sure) purposely block RSAP (I am not sure why), so you are not going to have any luck with it if your phone is from one of these.
Tried it with S7 Edge, sure it connects but then on less than 30 seconds she gets booted off/disconnect. Plug-n-play module that upgrades the stock system is at £504.72.
http://www.flyingspares.com/shop/blu....html?___SID=U
