Do I need new brakes? Do they "chirp"? Warning light? '09 Flying Spur
Old 10-28-2016 | 03:54 AM
cduluk1's Avatar
cduluk1 is infamous around these parts
Hi all:
My pre-owned 09 Flying Spur (standard type, i.e: NOT SPEED Ed.) has 64,000 miles and I am hearing a "chirp" whenever I use the brakes. I assumed this meant that I need new brakes.
But... My Bentley mechanic told me that the Bentley brakes don't have the tab that produces the "chirp" like normal cars to indicate they are low. Rather, he said, I would receive a warning indication on the dash. I don't have any such warning. I don't have a manual so I can't confirm this.
Is this true? If so, what might the chirp be that I am hearing? Thanks!
Old 10-28-2016 | 09:44 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Not sure about chirp, as that does not seem normal. You mechanic is correct there is a dash warning light, and when it goes off you have only a bit of time before making the change. Hope this helps.
Old 10-28-2016 | 12:00 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
What year started tonhave the warning light? 04 doesn't seem to have this.
Old 10-28-2016 | 01:39 PM
2006 I think, the 2007 GTC has it.
Old 11-01-2016 | 02:48 PM
cduluk1's Avatar
Damn. yeah it's a very defined chirp. What could I look for??
Old 11-01-2016 | 07:10 PM
i dunno without being there. Maybe have a brake specialist take a look, as it is only a VW Phaeton really.
Old 11-02-2016 | 08:14 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
I had a stone stuck between the disc and the backplate a while ago, it might be worth taking the wheels off and checking.
Remember to put the car into jacking mode first.
Les.
Old 11-08-2016 | 06:20 PM
jc_333's Avatar
jc_333 is infamous around these parts
Sounds to me you need new pads, could be brake pad backing plate making contact with disc. My rear inner pads were worn right down whilst outer was okay and making a high pitch squeak everytime i stopped.
Front or rear pads only use one wear sensor so if other pad is worn no warning light will appear. Very easy to check outer pad but inner will need wheel off.
J
