Bentley GT suspension ride height
#46
I wanted to add just a few notes and comments to this very valuable thread.
For my 06 GT my code was 0005561 and that worked for mine.
NOTE the two rear sensors need to move in the SAME direction (not mirrored like you might assume). You might make the same mistake i made and put the two leveling arms pointing in opposite directions. Don't. They both need to rotate in the same respective direction.
It is easily possible to install the sensor bracket arm so that the leveling sensor is actually reading the opposite of what it should be, because its rotating in the wrong direction.
I used the live data with the car in the air and the brackets removed to realize that very easy mistake.
