Bentley FS error codes P000D and 01583 - camshaft positioner and leak in suspension
Asking for help on behalf of a friends 08 FS.
Can anyone shed any light what is causing the camshaft positioner fault and if this is a simple part replacement?
Also what does the electrical fault in circuit mean as suspension height and hardness are functional. Vehicle will be lifted to inspect lines to locate any possible line pitching but any common areas for leaks?
I tested the FS and it feels the suspension is not responding fast enough to read the road properly. Vehicle felt disconnected but bushes look fine so thinking the leak has something to do with the ride quality.
Thanks!
J
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Part No SW: 07C 906 018 FL HW: 07C 906 018 FK
Component: BY - 6.0 L - TT G ª3472
Revision: --H01--- Serial number: VWX3Z0G7664699
Coding: 0021175
Shop #: WSC 06505 109 60459
VCID: 74E7A21814029BE2BA-5140
1 Fault Found:
000013 - Camshaft Positioner (Bank 2 Exhaust)
P000D - 008 - Slow Response - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 64163 km
Time Indication: 0
Freeze Frame:
RPM: 1482 /min
Load: 31.8 %
Speed: 14.0 km/h
Temperature: 105.0°C
Temperature: 67.0°C
Absolute Pres.: 950.0 mbar
Voltage: 13.208 V
Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W5 907 553 A
Component: LUFTFDR.-CDC- 3C3V0 7035
Coding: 0005551
Shop #: WSC 00092 106 182479
VCID: 3D71473C60C81AAA85-8068
5 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
012 - Electrical Fault in Circuit - Intermittent
00775 - Level Control System Sensor; Rear Right (G77)
00776 - Level Control System Sensor; Left Front (G78)
01769 - Sensor for Vehicle Leveling; Front Right (G289)
01583 - Leak in System Detected
000 - - - Intermittent
Thanks!
J
Coding: 0021175
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 64163 km
Time Indication: 0
Freeze Frame:
RPM: 1482 /min
Load: 31.8 %
Speed: 14.0 km/h
Temperature: 67.0°C
Voltage: 13.208 V
Coding: 0005551
5 Faults Found:
