TPMS and bonnet indicator issues
Old 10-09-2017 | 05:33 PM
tqd7mb's Avatar
tqd7mb is infamous around these parts
Hello,
I recently bought an 06 Spur. Great car, part of the inspection was TPMS not working. The module was replaced. drove 1000 miles in dry conditions no issues. Noticed rear cigarette lighter charger wasn't working. Changed fuse no issue. It started raining and then the Parking light went (Yellow P with slash), then the TMPS went out and then the bonnet light went off indicating hood not closed. Got home put in garage, I played with Electric brake button and Yellow P went off. Did reset and looks like all lights went off. About 2 hours later TPMS went off along with Hood indicator. I unplugged TPMS module that was replaced at dealer and plugged back in. The TPMS now working and red hood light went off. About 30 minutes later TPMS and hood open indicator came on again?
1-Are the TPMS and hood open indicator linked in any way by a fuse?
2-Does this sound like a module issue or wiring issue.
Thanks everyone, new to this and just needing help for a newbie....Chris
Old 10-09-2017 | 06:45 PM
Arachnophobia's Avatar
Arachnophobia is infamous around these partsArachnophobia is infamous around these parts
I am not sure if this helps but check your batteries, I have noticed weird things start happening if they are not sufficiently charged. Good luck with it and make sure you let us know what you come up with.
Old 10-09-2017 | 08:49 PM
riozilla's Avatar
riozilla is infamous around these parts
Where exactly is the TPMS monitor located that you unplugged and then plugged back in? I ask as I don’t know and would like to try that or replace it on my CGT. Sorry that I couldn’t answer your questions.
Old 10-10-2017 | 10:12 AM
tqd7mb's Avatar
The tpms for the flying spur is located in truck drivers side panel where battery is. It's clipped on to bottom of fuse panel. It's vanilla colored. The gt may be different. I saw somewhere it was located behind rear seat in quarter panel but I'm not sure.
