bentley flying spur p0243
hi guys
need a little help with my daily. new to the forum so a big HELLO to everybody and forgive me if this has already been posted.
my Bentley continental flying spur w12 2005 has developed an error code p0243 - waste gate solenoid ?
is this the sensor at the front of the engine ? as i have already changed this around 3 months ago after accidentally breaking it whilst taking the intake manifold off.
or does this error relate to the sensors at the back of the engine? or even a vacuum leak which i have a hunch it will be.
do i need to take the engine out the get to the sensors at the back?
any help is appropriated.
thanks in advance
thanks in advance
Hi Saads,
I have same model and issue. Pressure control valves were replaced, however no improvement. I can reset the error when car has been off for some time. After around 25 minutes of engine on, the error resurfaces. How did you resolve? I am a little bit worried to take engine out given complexity and risk of damaging further.
Thanks for considering to answer. Best
Hi Saads,
Saads only has 1 post and it is from 2017, he never came back with any update....
Check this thread.
https://www.6speedonline.com/forums/...ley-p0243.html
Johnny
Same issue
Hello
Wondering if you have any updates on this? It seems I have exactly the same symptoms on my 2005 continental GT. All the vacuum lines that can be checked for leaks without removing the engine semm to be perfectly fine.
I did however find out that the left hand side exhaust valve doesn't work - seems to be the electric solenoid (??) Right at the back of the car, vacuum is fine At the back. Haven't repaired it yet, since I only found out yesterday.
Could this even possibly be the reason for the p0243?
Cheers
Cheers
samuell
Bentley
17
11-03-2018 08:54 PM
