04 Bentley Misfire
Old 01-14-2018 | 10:45 AM
MisterBojangles's Avatar
MisterBojangles is infamous around these parts
04 Bentley Misfire
Got the code cylinder 9 wasn't working.
The mechanic did the following:
Changed battery
changed oil
changed 12 spark plugs
changed coil #9
changed an exhaust solenoid that was melted
the misfire is still happening and he now doesn't know what the problem is and the engine light is staying on
Any ideas?
Old 01-15-2018 | 08:03 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
What specific DTC codes did you get? What diagnostic tool are you using?
Old 01-15-2018 | 01:45 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Personally, I'd change all coils if you're not sure their age.
Old 01-17-2018 | 05:47 PM
Swflbt23's Avatar
Swflbt23 has a spectacular aura aboutSwflbt23 has a spectacular aura aboutSwflbt23 has a spectacular aura about
As stated above if one coil went out I’d replace all of them. If the misfire is consistent I would swap the injector to another cylinder and see if the fault follows. If not check the injector and coil are receiving proper power and ground if they are then move to mechanical error and check compression.
Old 02-04-2018 | 09:14 AM
MrVette's Avatar
MrVette is infamous around these parts
I would have thought coil. But since you replaced it I'm stumped.
I had a misfire on #2 and replaced just that coil along with all 12 plugs. No problem since.
IMHO no need to replace all coils. While defective coils are a known problem not every coil misfires.
Hawkinz69
Bentley
34
06-09-2018 10:27 AM
911_maestro
08-15-2011 01:27 AM
superfans
07-28-2005 08:09 PM
Ubermensch
07-27-2005 01:45 PM
Carmel
04-26-2005 04:44 PM
Quick Reply: 04 Bentley Misfire
