Level Fault Workshop
Old 01-22-2018 | 06:34 AM
tarnow1942's Avatar
tarnow1942 is infamous around these parts
The above fault came up on my 2005 Bentley. I hoisted the car and saw the sensor rod on the Right front disconnected. (probably snow). I reconnected the sensor rod and the fault still keeps coming up a minute after I start the car and it still seems to be sitting 1" lower on the right front. Please help.
Old 01-22-2018 | 03:56 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
I trust you put it in "jacking mode" before you lifted it. Try driving it around the block. I will probably re-adjust itself.
Old 01-23-2018 | 08:01 AM
Forster1993's Avatar
Forster1993 is infamous around these parts
Or if you didn't put it in jack mode. Put it into jack mode then take it out again.
I also got this fault when I had a low battery
Old 01-23-2018 | 10:08 AM
larryr's Avatar
larryr has a spectacular aura aboutlarryr has a spectacular aura about
it may be a leaking strut. see several threads and be advised rebuilt struts are available
Old 01-23-2018 | 10:41 AM
tarnow1942's Avatar
likely a leaking strut,as putting it in jack mode and lifting it up and down doesn't erase the massage. How to find the leak? I have a hoist. Sptay soapy water and look for bubbles ? Or? any ideas,and by the way,thank all for taking the time to answer. Great forum. I know its the R front as that's where the sensor strut disconnected itself. Car sits 1" lower on R front. Love this car, better than my Ferrari and Porsche. Hate to give up and take it to a dealer.
Old 01-23-2018 | 03:07 PM
PMS's Avatar
PMS
have you driven it since you reconnected the sensor rod? The error light won't go out until you drive the car. It doesn't have to go far...i.e. half a city block.
Mister PINK
09-22-2024 12:10 PM
toughluck
02-25-2014 08:42 AM
lilo1980
Bentley
11
12-28-2013 06:57 PM
Porsche05
03-07-2013 09:15 PM
wingedone
Bentley
06-01-2012 09:05 AM
Quick Reply: Level Fault Workshop
