Passenger side front grinding sound
Hi
I have a 2007 GTC.
I had my front passenger side air shock go down and I had the GTC towed to a mechanic. The mechanic replaced the air shock and I drove far away. When I returned home and turned into my driveway I heard a grinding noise only while I turn sharp left ....I had a friend turn the steering wheel all the way to the left and ease forward and back while I was on the ground listening and I can safely say that the grinding noise is coming from the inside of the tire and rim. Like either the brakes or deep inside there. The grinding is like metal on metal. The wheel/rim is not hitting the new shock or plastic shielding......would your all be si kind as to help?
I have a 2007 GTC.
Hi
I have a 2007 GTC.
I have a 2007 GTC.
Ron
Hi, could be something simple. With my GT on occasion when driving you get a small stone which gets caught between the disc/rotor and the protective shield. Makes a real grinding noise. Removal comes from sometimes alternatively driving slowly forwards and backwards and falls out on its own accord, or wheel off and poke out. Just worth checking and hope it's this. Kind regards, mick.
thankswww
03-01-2012 09:51 PM
