Bentley CV Axle replacement
Old 11-23-2018 | 11:15 AM
gtjay's Avatar
gtjay is infamous around these parts
hey guys, I recently replaced all my front control arms and while doing so I noticed that I’ll be needing a new right cv axle. I had brought control arms for a Phaeton and they all fit into my conti gt no problem. Would CV axle from phaeton fit onto my conti as well?
Old 11-23-2018 | 04:09 PM
1eapplebaum's Avatar
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
The difference could be the diameter of the axel shaft. The Audi Quattro's are the same configuration, however, the diameter of the axle shaft is smaller then Bentley. Intuition suggest the Phantom would fit, double check the diameter of the axle shaft.
Should the CV boots be torn, one of the Audi Quattro boot kits will fit the BentleyGT. That part will require research to cross reference.
Old 12-09-2020 | 11:44 AM
Jurgeenh Borbon's Avatar
Jurgeenh Borbon is infamous around these parts
Did the CV axle of the Phaeton work fine in your Bentley?
bobbally
Bentley
07-14-2023 09:54 AM
Jurgeenh Borbon
Bentley
09-24-2022 03:34 PM
gtjay
Bentley
14
04-21-2021 09:25 AM
Kes
Bentley
07-10-2018 11:53 AM
Seta79
04-14-2018 06:08 AM
Quick Reply: Bentley CV Axle replacement
