How to remove belt tension from tensioner to replace serpentine belt
Old 02-18-2019 | 03:25 PM
Dave01gt's Avatar
Dave01gt is infamous around these parts
I just got a new serpentine belt for my 06 Continental GT. How do you remove the tension from the tensioner? I see 2 13mm bolts, a 16mm that bolts the the block and a hex bolt on the pulley. Which is used to remove tension? Thanks in advance.
Old 02-18-2019 | 05:14 PM
1eapplebaum's Avatar
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Old 02-18-2019 | 05:20 PM
Dave01gt's Avatar
Originally Posted by 1eapplebaum
Thanks! Is there a bolt I have to remove first to get it to move?
Old 06-17-2020 | 09:24 AM
adrian meadows's Avatar
adrian meadows is infamous around these parts
Hi..
Sorry to trouble you.
The tensioner hex you have ringed.
I have put a new belt on my Bentley.. through the space created when you remove the bonnet bash plate..narrow but doable.. just.. but wanted to get a socket/spanner on the tensioner to compress it and complete the job. Being a bit ahead of myself I didn’t measure the hex size with the belt not there (idiot) and it’s not easy to get in there at all.
Is it a 22mm or 24mm.
Kind regards
Adrian Meadows
TeamJones1962
Bentley
32
12-15-2020 03:28 PM
cuddapah
11-03-2018 04:56 PM
blue2000s
06-29-2016 08:48 AM
Car-Narcissist
04-10-2011 06:09 AM
Quick Reply: How to remove belt tension from tensioner to replace serpentine belt
