Bentley FS body vibrations on acceleration
Old 01-19-2020 | 01:00 PM
Bentley45's Avatar
Bentley45 is infamous around these parts
Nothing should be in your way once you take bottom plastic cover off. Good luck
  #32
Old 03-07-2020 | 01:04 PM
Martin Cassidy's Avatar
Registered PM
Martin Cassidy is infamous around these parts
Originally Posted by Martin Cassidy
Hello. I am having a high pitched vibration noise coming through my gearbox shifter. Could you please tell me what kind of noise vibration you were having. Also if possible could you please give me the part numbers for the replaced control arms. I cant indentify the upper lower control arm from your picture. The vibration is driving me mad. Thank you.
Thanks for reply
  #33
Old 03-07-2020 | 01:15 PM
Bentley45's Avatar
Before you replace the control arms check to see if you still get the vibration with the car in park? Step on your gas pedal and see if you get the shaking. Because my problem ended up being 2 motor mounts that did not throw any codes. So it’s hard to diagnose.
  #34
Old 03-07-2020 | 03:00 PM
Bentley45's Avatar
I all most forgot you will need 2 motor mounts and 2 transmission mounts.
yanacha
Bentley
30
03-25-2019 04:10 PM
Tedd930
Bentley
02-19-2019 01:18 AM
Robblow
Bentley
08-24-2018 06:31 PM
temi
Bentley
01-04-2018 03:11 PM
therron4ou
Bentley
05-18-2017 01:23 AM
Quick Reply: Bentley FS body vibrations on acceleration
