Brake Fluid go bad if a car has been sitting for 3.5 years?
Old 04-18-2019 | 08:18 AM
MBi's Avatar
MBi
MBi is infamous around these parts
Originally Posted by Rico.Adams
How to do your own Brake Fluid Test ...
As with every other fluid in your car, brake fluid contains a main ingredient along with protective additives. The main ingredient in brake fluid doesn’t degrade, but the additives do. The most important additive is a corrosion inhibitor. The corrosion inhibitor prevents internal rusting of steel brake lines, calipers and ABS (antilock brake system) components. Once the inhibitors are exhausted, even minute amounts of moisture can cause dangerous and costly corrosion.
Most car manufacturers recommend a complete brake fluid flush every two years or 24,000 miles. Rather than rely on a general recommendation, you can test the actual condition of your brake fluid. To check your brake fluid, remove the cover of the master cylinder and dip a strip into the fluid. Shake off the excess fluid and wait 60 seconds before comparing the color of the strip with the guide on the brake fluid tester package.
Thank you for the detailed explanation, I will do that test on the other cars I maintain (14 GranTurismo and 12 California). I wonder how often the brake fluid has been changed under the Ferrari 7 year included maintenance on the California. You all have been very helpful!
Old 04-18-2019 | 11:26 AM
Rico.Adams's Avatar
Rico.Adams is infamous around these parts
Let us know your findings ...
Old 04-18-2019 | 11:49 AM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
I have a 458 under the 7 year warrantee, Ferrari flushes brake fluid and changes oil and filter every year, no matter mileage.
Old 04-18-2019 | 11:59 AM
Rico.Adams's Avatar
Correct when I had my Tesstarossa they did the same, but to be honest its not necessary every year, they just do it for the warrenty, I did ask them & that's the answer they gave me ...
Old 04-18-2019 | 01:59 PM
mto's Avatar
mto
Agree, brake fluid once a year not required. Unless couple of track days. Two years is best, otherwise can do harm to brake system. Cheap insurance, imo.
Old 04-18-2019 | 02:37 PM
BWings's Avatar
BWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant future
Yes, agree....a tracked car changes everything....
Old 04-27-2019 | 09:16 PM
MBi's Avatar
MBi
Service department agreed to flush the brake fluid before delivery. All good no issues knock on wood.
jrblackbox
914/914-6
11-19-2015 08:01 AM
ArashApollo
03-05-2013 05:05 PM
Quick Reply: Brake Fluid go bad if a car has been sitting for 3.5 years?
