Bentley 2010 CFS new LED headlight upgrade!!!!
#48
Lights
I can’t find the instructions my guy must have trashed them but I had him open the box and hood to see connections. One wire joins the two lights and then goes to fuse number 10 which is unused in my car. Pictures below
Fuse box under steering wheel
Connection under engine for passengers side to driver side lights which join together.
I’m confused with this brown wire that connects both lights together then to fuse 10. The pictures I see from fishcakes is 2 brown wires without the connector shown in your picture. I’m really close to pulling the trigger on these lights just want to understand before.
#49
It’s real simple 2 brown wires 1 from each light plug into each other then plug into the fuse box for power. This brown wire only controls your daytime running lights. The other wires are plug and play just like factory.
#50
gotcha. So does the brown wire have a connector or I have to splice them? Any issues with the lights?
