Plastic shifter slider thing part number if anyone wants
Old 06-04-2019 | 04:39 PM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
Just had a friend PM me about the part number for the shifter plastic sliding part, someone else found the part number, so I can't take credit. I ordered it on Ebay and got it fairly quickly for $60 or so, I think the Bentley part is several hundred dollars, it's the same thing.
https://www.ebay.com/itm/192662876216?ul_noapp=true
Old 02-06-2020 | 01:11 PM
British's Avatar
And to follow up, the part worked perfectly and was an easy install. Magnets were correctly located.
Old 02-06-2020 | 01:31 PM
Randy V's Avatar
Randy V is infamous around these parts
Did you find instructions on how to do the job or did you figure it out for yourself?
Looking at the shifter bezel on my car I can't see how it is attached to the console.
Old 02-06-2020 | 04:14 PM
British's Avatar
Johnny knows how to do it. I don't think it's all that difficult, my stereo install shop just accepted the part and said they'd put it on, and that "every Bentley that comes in wants this", which is probably exaggerating but they didn't charge me for it and knew how to change it. I know you have to pull out the center console, which is why I asked them to do it, since it was all coming out for the Ben Hur install.
Anyway, ask Johnny Hotspur or one of the other manly men on here that do their own work.
Old 02-06-2020 | 04:23 PM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
If Johnny does know how to do this I sure hope he post how. Mines been sitting on the shelf for almost a year.
Old 02-06-2020 | 04:45 PM
Johnny Hotspur GT's Avatar
Administrator
Give me some time to get pics and info together, stuck at work, blew an other hydraulic hose on S600 ABC suspension system on the way in today.... UBER ride home time, gotta fire up the 05 A8l W12 tonight after work, then I will get some pics of shifter gate...
I will, I will...
Old 02-08-2020 | 08:59 AM
Administrator
Hello All,
Just wanted to update that I never left work yet, so I did not get you all the info yet, I WILL be leaving work tonight and shall get the pics and info Sunday/Monday.
Sorry for the wait.
Johnny
Old 02-08-2020 | 06:28 PM
Administrator
Hello All,
I am going to assume that you all know how to remove the shifter **** and the center console wood trim.
So please see my pictures for the removal of the round PRD and shifter gate slider, in the first pictures you will see 4 clips, 2 for each side, unplug the wiring to the shifter gate, and then release the 4 clips to lift the assembly straight up, next you will see my thumb on one side and my fingers on the other side, hold the assembly as shown and squeeze with thumb and finger to release black plastic assembly from the round shifter piece, next you will see 10 clips to unclip, (PLEASE BE GENTLE) there will be 6 in the center (3 each side) and 2 at each end, some were already broken and missing on the unit I am using for information, so I marked all the spots with red, once you unclip the 10 spots, lift the inner cover off to access the slider and replace.
Johnny
Old 03-28-2020 | 11:32 AM
Randy V's Avatar
Item 5 in this diagram is the cover piece?
Is there instructions somewhere on removing the shifter and console wood trim?
Old 03-28-2020 | 11:50 AM
British's Avatar
Johnny can help there. There are also threads on here on how to do it. I had my radio installer do it, he had done them before, so it couldn't have been that difficult.
Also anything thinking about buying that piece, Ebay shows "94% sold" if that means anything. I'm sure more can be found under the part number, but I had good luck with this shipper.
Old 04-04-2020 | 12:50 PM
Randy V's Avatar
I'm ready to order the replacement part.
Is there a write-up that describes removal of the center console and shifter surround?
Old 04-10-2020 | 08:44 PM
Randy V's Avatar
Lads?
Social distancing not required here.
LOL
Old 04-11-2020 | 11:24 AM
Randy V's Avatar
Just ordered the part. While I await its arrival will look for full installation instructions! Thanks British.
Old 06-18-2020 | 12:32 PM
BruceR's Avatar
BruceR is infamous around these parts
The part on the ebay link is now up to $93 but there are some others, also from Latvia for a bit less but with multi week delivery. In searching around I found that Jim Ellis VW in Atlanta sells the part (Audi p/n 4E1713187A) for $101.26 with free shipping and ordered it. Got it in one week and here are some photos. My mechanic friend has done it many times and is going to put it in tomorrow and says it'll only take 15 minutes.
Old 06-18-2020 | 12:39 PM
British's Avatar
You're going to like your car more after it goes in. Nobody else notices it, but it made me crazy; after putting it in, it feels much better. I think I spent $60, but I'd do it for $100 without blinking an eye. It's like the difference between driving around with a check engine light on or off.
Good call on changing it.
Quick Reply: Plastic shifter slider thing part number if anyone wants
