Bentley Continental GT 2005 strange engine sound on start up and during drive
Hi everyone, I've got a Bentley GT 2005.
My car has started to make a strained engine sound everytime I start the car and is there when I'm driving it too.
I was wondering if someone could help me diagnose what this sound is coming from the engine bay.
It only started making this sound yesterday.
I've made a short clip of the the ignition cycle and you can hear it when it fires up.
Video LINK of issue>> - Bentley Continental GT Engine strange noise - YouTube
Any help is appreciated. Also, if anyone knows what the remedy is and roughly what it entails.
I'm based in the Midlands UK so any recommendations where to get it fixed would be great.
Thanks for the feedback - is this where the power steering fluid goes? I checked this and it is at minimum level so I can top this up with the chf11. I'm wondering whether this resolve the noisy power steering pump if this was the place for the power steering fluid?Thanks
That's it. Hopefully that resolves the noise. Should the noise persist then evaluation of the power steering pump and rack and pinion is in order. The fluid went somewhere so suggest having the car lifted and looking around the plastic under shield for dampness. Should there be a slight leak good to catch it now before it becomes a big leak.
I'll keep you posted.
It turns out to be a hydraulic leak in one of the power steering pipes. One pipe heavily corroded and split.
1st option - replace existing piping
2nd option - repair the leak using copper piping
The 2nd option costs less due to less labour time / parts material.
The garage also found that the steering rack has slight leak from offside track rod end gaiter area. Could this be repaired / reconditioned or does it need replacing? Can I leave the steering rack alone ?
Update:
Update
I got my car back in Friday. I managed to get the steering rack reconditioned with new seals etc from a local company in the Midlands. I had a local garage to them remove and refit the rack all for a very reasonable price. The garage also changed the damaged high pressure hose with new factory parts I ordered. Overall very happy with the result and can feel the steering really light when making 3 point turns.
What I learned is that it is best to shop around and get opinions on what is best course of action especially when it could cost a lot of money.
Update
Thanks to everyone for the advice!
