Bentley Continental Alarm chip coding
Nice! Would you mind sharing the settings?
At first, I liked the silent operation as I thought it's nice and inconspicuous.
However, as time passes, I miss having a reassuring chrip confirming the car is locked and the contents are safe inside, being able to simply walk away without having to turn around and look for the telltale flash of the lights or red flash top of the door cards.
I used VCDS to turn the "chirp on" it was pretty simple for me to be able to do it!
I also changed the the 3 flash indicator to 4, just because I could!
Cheers Pete.
Hi Iain,
Yes, no problem.
I've taken a few step by step screen shots to help, so;
1. Open VCDS software & click Select on "Select Control Module"
2. Click on Module 46 - Central Conv.
3. Click on the drop down menu & select "Locking confirmation via remote control button preference"
4. In "New Value" box type in 3 & click save
& thats it!
If you also want the same settings for comfort access just go through the same procedure above but under "Locking confirmation via Kessey (keyless) preferences"
You can see from the drop down menu that there's a few other preferences you can play with whilst here!
Hope the above helps!
Cheers Pete.
Yes, no problem.
& thats it!
Cheers Pete.
I wound up purchasing the Ross-Tech VCDS Hex-V2 ($199.00)
Just made my update for a sound verification (Chirp - it is pretty loud by the way) for my keyless, keyed and remote - open/close functions
Easier than I expected - but only thanks to Pete.
Pete - THANK YOU
Pete - THANK YOU
Hey, no worries, just happy to be of some assistance!
Thanks Pete!
Hi Iain,
Yes, no problem.
& thats it!
Cheers Pete.
Yes, no problem.
& thats it!
Cheers Pete.
