GTC Clanging noise & dip in RPMs at Hwy Speeds
Old 08-25-2019 | 12:12 PM
Martin Perri's Avatar
Martin Perri is infamous around these parts
I am trying to determine what this rattle clanging noise is coming from the underside of my GTC? I notice this only when window is down and when going over bumps, the air shocks are all performing well and no sign of those being an issue, it doesn't sound like a wheel bearing... if one can describe a noise which is difficult its not a rattle, a bang, a squeal, a buzz, .. its more like a loose clanging noise of metal as if something is loose underneath, I just don't know where to begin. I was watching a back and forth video of the Person in Vietnam whom was trying to isolate the noise on his Silver Spur and after replacing sub frame bushings and elements like driveshaft, sway bar... it ended up being the Automatic Door Locks at Low speed malfunctioning. I know that is not the issue, if I knew anything about cars it would be frightening, but it has the sound of a shock bottoming out is the only way I can describe this. its not effecting the vehicle overall but just want to make sure that the bottom doesn't fall off the car at high speed! . I would certainly take it to the Bentley Garage but its two hours away, but it just might come down to this if I cant easily identify what it is.
The other thing that i have noticed is while driving at 65-70 on freeway the vehicle dips down all the sudden in RPM for no apparent reason at all, I haven't noticed this at lower speeds, just at highway speeds and if someone has tied a tether to the back and is pulling me backwards. Weird and very intermittent
Old 08-25-2019 | 02:12 PM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Originally Posted by Rico.Adams
Hi Martin ... do a small video like our friend did maybe we can identify the problem ....
Also, If your comfortable with jacking it up, start off with checking all your control arms front and back.
untitled
Cayenne 955/957
03-30-2015 11:38 PM
porscheconvert
01-11-2010 02:10 PM
solrac6262
09-29-2009 06:47 PM
kcphuah
11-10-2007 09:43 AM
stanmo
11-23-2004 05:33 PM
Quick Reply: GTC Clanging noise & dip in RPMs at Hwy Speeds
