When the Air Suspension Compressor fails, Try This DIY
Old 09-23-2019 | 10:40 AM
Rico.Adams's Avatar
Rico.Adams is infamous around these parts
Originally Posted by alenmunro
Will check Thank you.
Your welcome, let us know how you get on ...
Old 01-19-2020 | 10:09 AM
Mark Thwaites's Avatar
Mark Thwaites is infamous around these parts
suspension fault
can anyone shed any light, i have a 2004 Bentley continental gt, when car was purchased at auction the suspension was all sunk to the ground after getting the car started the suspension raised to maximum hieght now the front is locked out at maxed hieght and the rear sits and standered ride hight, i have replaced main power fuse to cenral electronics and both batteries, run a test on the suspension trying to raise and lower each corner independently, again rears perfect front nothing.
Old 01-19-2020 | 10:35 AM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
I would look at the level control sensors on the front struts , for connection and the wiring is good .
Old 01-19-2020 | 10:50 AM
I will double check and clean up all connections with some contact cleaner, as i say it did function all that's happened since is it was driven into a trailer and transported had to change both batteries as nether were delivering the right amps. everything else now works perfect it's just the front suspension.
Old 01-19-2020 | 11:21 PM
Rons GT Speed's Avatar
Rons GT Speed is infamous around these parts
Thank you for sharing your expertise and quality pictures. Great information.
Old 01-20-2020 | 01:55 PM
Samhain's Avatar
Samhain is infamous around these parts
Sounds like one of your level sensors is bad. And having good batteries with these cars is a MUST. Subpar batteries will cause all sorts of weird problems.
Old 05-12-2020 | 03:35 PM
Csaby Ttz's Avatar
Csaby Ttz is infamous around these parts
2005 Bentley continental Suspension relay
how I can find the compressor relay. Thank you
Old 09-27-2020 | 01:22 PM
Dg 27's Avatar
Dg 27 is infamous around these parts
wow thats great thanks for info brilliant
Old 01-24-2023 | 03:07 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
raise and lower each corner independently?
how it can be done???
Old 01-24-2023 | 11:09 AM
Johnny Hotspur GT's Avatar
Administrator
@sazam ,
With the Ross-Tech VCDS in address # 34, output test.
Or you can go under the vehicle and disconnect one rod at a time, then by moving the sensor lever up or down, that corner will react.
Johnny
ciaka
09-19-2024 06:32 PM
2010panamera1
09-08-2024 12:22 AM
ciaka
12-28-2022 08:54 AM
belton
Bentley
22
10-06-2020 10:11 AM
ciaka
Cayenne 955/957
05-15-2014 04:40 PM
Quick Reply: When the Air Suspension Compressor fails, Try This DIY
