Rear Led Tail Lamp rebuild
Old 10-02-2019 | 04:55 AM
Rico.Adams's Avatar
Rico.Adams is infamous around these parts
NG ... You should tint the inner part of the light (not the lens) they look great, if I ever get round to it Id do mine ...
From this :-
To this :-
A lot of owners tint the whole outer lens with a dark film, personally Im not a fan of that, but yah if you like the look sort it ...
  #32
Old 10-04-2019 | 07:06 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
@Rico.Adams I didn't have time to play with it yet... maybe I will buy a brand new one...
sadly ... hì hì
  #33
Old 10-04-2019 | 08:55 AM
Rico.Adams's Avatar
sadly ... hì hì
Oh well thats a shame after all that effort you put into it, If you do go for the option of buying new lights then if you ever have time see if you can split them apart ...
  #34
Old 10-04-2019 | 09:10 AM
@Rico.Adams I will buy a new light first before I split them a part because in here part is rare and hard to find.. I need to wait a month in order to get it..
if I break the lens.. I don't have car to drive in a month..
  #35
Old 10-04-2019 | 09:14 AM
Rico.Adams's Avatar
Yes off course I didn't expect you to take them apart before you had new ones to replace ... Are there many dealerships where you are & are Bentleys rare or plenty about ...
  #36
Old 10-04-2019 | 09:19 AM
@Rico.Adams well, there re none dealership here.. in my country has total about 40 or 50 car..
I have 2 of them ,,
  #37
Old 10-04-2019 | 09:24 AM
Rico.Adams's Avatar
I have 2 of them ,,
Wow, You must be a king there NG ...
  #38
Old 10-04-2019 | 09:27 AM
@Rico.Adams lol.. of course no.. I bought it used here actually ha ha
  #39
Old 10-04-2019 | 09:34 AM
Rico.Adams's Avatar
Now you being Modest my friend ... You are King, Im going to address you as King from now ...
  #40
Old 11-23-2019 | 04:51 AM
Hello all...
after long time finding what wrong with it.. then I found out it actually soldering issue...
the Led got Hot then it burn of the solder under it...
the only way to test it is take it off.. power it.. then use your hand to press at it...
or just resolder every LED on the Big Oval board which has the turn signal and the brake light...
here is the photos...
after soldering
Before solder
cut the MESH in order to take off.. the place u cut won't hurt anything because it actually open
All LED ON
  #41
Old 11-23-2019 | 05:01 AM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
Great work! Nice job finding the seam where they come apart, will be very helpful to others in the future.
What a crazy design on the circuit board! Guess getting the curve right was accomplished by splitting the board and joining with the ribbon cable interconnects.
Sad to see those little can capacitors on the board though.
  #42
Old 10-15-2020 | 02:42 PM
ramvanapalli's Avatar
ramvanapalli is infamous around these parts
Bentley Tail Light Issue
Am having an issue with my Bentley tail lights also. The led's on the turn signal work intermittently, and some of the Led's dont seem to be wokring. Anyone have any luck fixing them?
TheInfamousDrew
07-24-2017 02:53 AM
PSPorsche
03-14-2014 12:07 PM
Ray33
12-18-2013 08:41 AM
TYE
08-12-2013 12:25 AM
Quick Reply: Rear Led Tail Lamp rebuild
