Anyone have issues with power surges on start?
Old 09-03-2019 | 12:11 PM
Rico.Adams's Avatar
Rico.Adams is infamous around these parts
Originally Posted by TeamJones1962
I do know the circuit board is a lil “ehhh” on the Ben Hur...and that power goes into it and back out via this board. IF the wiring checks out, I would look at the power going into it and coming out. The solder points might not be so solid. Just my 2 cents
TJ ... what soldering is there, the BenHur has all the looms that wire direct onto all the other wiring including the head unit, unless they chopped wires which I find difficult to understand ...
Old 09-03-2019 | 04:26 PM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
If you open it up, I’m sure where the power comes in it ties into the the circuit board to power it up. Atleast from the radios and amps I had to re-solder.
I just took my radio out. It looks like they use the factory plug to power up the Ben HUR. Then use the Ben HUR to power up the radio. Just maybe they should have used a pigtail, use that to go straight from the factory to power up the Ben HUR and the radio.
The harness I have circled, goes from the unit to your radio. They could have bypassed that so now the unit really has nothing to do with the radio as far as power goes.
Every manufacturer has a product failure percentage. Maybe British just got two that was made by Fred on a Friday right before closing or that Monday after a weekend of bar hopping 🤭😂🤣
Old 09-09-2019 | 06:07 PM
Rico.Adams's Avatar
This Thread ... British, read my post & ask your installers, Im very curious to how your systems been wired up ...
Old 09-10-2019 | 04:32 AM
Rico.Adams's Avatar
Ive given this a long hard think !!! why is the BenHur burning out, not just once but twice.
This is my theory ... Your installers have used 1 set of RCA's to connect to the BenHur which then feed sound to the stock amp which is fine as long as you're happy missing that other channel.
Now how have they connected the SUB, I think they've used the other set of RCA's & ran that through the BenHur which is over loading the BehHur & burning out, due to the BenHur using the same power circuit as the head unit both units fail due to the fuse blowout, or they've used the SUB out from the head unit & ran that through the BenHur still causing it to burnout, Its impossible to burnout 2 units in such a short period on one car, I cant see any other way they've connected the SUB.
I may be totally wrong & they have used an after market amp to run the SUB, you haven mentioned that tho, then it comes down to wiring (power) error, but that shouldn't burnout the unit just blow the fuse/s.
Take some pics & ask your guys how have they installed the new system ...
wkearney99
Cayenne 958
11-26-2016 07:13 AM
pat
06-21-2013 08:01 PM
adamclutz
12-12-2010 12:54 PM
Antw
Lamborghini
06-26-2008 08:19 PM
HawkDucati
Cayenne 955/957
04-11-2007 07:03 PM
Quick Reply: Anyone have issues with power surges on start?
