18995 - Turbocharger Boost Control Position Sensor Circuit
Hi guys getting this fault code on vcds 18995 - Turbocharger Boost Control Position Sensor Circuit
Does this mean I need to pull the motor to get at the sensors 🙈🙈 I'll add full scan so you can give advice of all the other faults it came up with ha ha.no warnings on dash car drives well considering these are meant to be faulty
Monday,02,December,2019,15:40:49:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: SCBCE63W74C023705 License Plate: MRO3MPH
Mileage: 145090km-90154mi Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W74C023705 Mileage: 145090km-90154miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No SW: 07C 906 018 AC HW:
Component: BY-6.0L-TT G ª6238
Coding: 0000173
Shop #: WSC 01666 772 36781
VCID: 66C300995267CA7A4F-5178
2 Faults Found:
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
P2563 - 008 - Implausible Signal
Readiness: 0000 1001
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 A HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1005
Coding: 0000101
Shop #: WSC 00000 000 00000
VCID: 2E53B8B9BA17423A77-5178
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 D
Component: ESP 5.7 4WD H01 0021
Coding: 0007878
Shop #: WSC 00082 000 00000
VCID: 366390D942477AFA3F-515A
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 F HW: 3D0 909 137 F
Component: 40 Kessy 6850
Revision: 00H22072 Serial number: VWZ3Z0D3151003
Coding: 0422125
Shop #: WSC 04940 001 00001
VCID: 2A5BB4A986FF2E1AAB-5178
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 00148 106 59863
VCID: 479DED1D35ADF37254-515A
2 Faults Found:
01971 - Adjuster for Seat Heating & Ventilation (E399)
009 - Open or Short to Ground - Intermittent
01903 - Seat Tilt Adjustment Motor (V231)
005 - No or Incorrect Basic Setting / Adaptation
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 007 M
Component: ZAB COCKPIT 0251
Coding: 0400335
Address 08: Auto HVAC Labels: None
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000001
VCID: 306FA6C1A02354CA65-5178
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
014 - Defective
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 G
Component: STG.Bordnetz 5001
Coding: 0000107
Shop #: WSC 00083 000 00000
3 Faults Found:
01498 - Bulb for Parking Lamps; Right (M3)
010 - Open or Short to Plus - Intermittent
00907 - Intervention load Management
000 - -
01755 - Switch for Parking Lights (E1)
008 - Implausible Signal - Intermittent
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Coding: 0000173
2 Faults Found:
19019 - Turbocharger Boost Control Position Sensor 2
P2587 - 008 - Implausible Signal
17497 - Mixture Regulation; Bank 2; Range 1
P1089 - 001 - Lean Limit Exceeded
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 25414795EFE1016286-515A
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 E
Component: Lenksäulenmodul 3401
Coding: 0000212
Shop #: WSC 00082 106 68715
VCID: 2F6DA5BDBD1D4B327C-515A
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 840 M
Component: KOMBIINSTRUMENT RB8 0402
Coding: 0021400
VCID: 3E7388F96A77B2BAE7-5178
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 00148 106 61016
VCID: 70EF66C160A314CA25-5178
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
VCID: 77FD5DDD05CD43F2E4-5178
1 Fault Found:
01583 - Leak in System Detected
000 - - - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
Shop #: WSC 00148 106 181989
VCID: 3F8DF5FD6D7DBBB2EC-5178
2 Faults Found:
01895 - Motor for Steering Column Adjustment; Vertical (V123)
Address 37: Navigation Labels: None
Part No: 3W0 919 887 B
Component: NAVIGATION 0168
Coding: 0400000
VCID: 4683E01932A7EA7AAF-515A
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0703
Coding: 0000157
VCID: 366390D942477AFA3F-5178
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 1L HSG 0101
Coding: 0000032
Shop #: WSC 00148 100 59863
VCID: 3365A9CD51356FD218-4B32
Subsystem 1 - Part No: 3W2 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W2 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Part No: 3W8 959 703 A
Component: Tuersteuergeraet HL 1002
Subsystem 4 - Part No: 3W3 959 704
Component: Tuersteuergeraet HR 0702
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
2 Faults Found:
01504 - Bulb for License-Plate Light (X)
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 C
Component: 12K-AUDIOVERST 4121
VCID: 3467AAD1543B68EA01-5178
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022413
VCID: 356197D55F4171E236-5178
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 306FA6C1F02354CA65-51EE
Address 57: TV Tuner Labels: 3D0-919-146.lbl
Part No: 3D0 919 146
Component: TV Tuner H07 1205
Coding: 0000010
VCID: 65C10795AF61C16246-5178
Address 65: Tire Pressure Labels: None
Part No: 3W0 907 273
Component: Reifendruckueberw. 0022
Coding: 0011344
Shop #: WSC 129056 041 00000
VCID: 76E350D902C73AFAFF-515A
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W2 955 023 C
Component: Wischermodul ª9323
Shop #: WSC 00000 725 65552
VCID: 377D9DDD454D83F224-5178
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 2345598DE1D5FF52E8-5178
Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AFB44E936DF5E9A9B-5178
12 Faults Found:
01549 - Supply Voltage for Parking-Aid Sensor
002 - Lower Limit Exceeded - Intermittent
01629 - Sensor for Parking-Aid; Front Left (G255)
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
00434 - Left Front Inner Parking Aid Sensor (G332)
00435 - Front Right Inner Parking Aid Sensor (G333)
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
01626 - Sensor for Parking-Aid; Front Right (G252)
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
00437 - Rear Right Inner Parking Aid Sensor (G335)
00436 - Rear Left Inner Parking Aid Sensor (G334)
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
006 - Short to Plus
Address 77: Telephone Labels: None
Part No: 3W0 035 729 K
Component: Telefon 0252
End-------------------------(Elapsed Time: 07:13)--------------------------
www.Ross-Tech.com
Coding: 0000173
2 Faults Found:
P1923 - 008 -
Coding: 0000101
Coding: 0007878
Coding: 0422125
Component: ELV XXXX
Coding: 0000002
2 Faults Found:
Coding: 0400335
Coding: 0000001
1 Fault Found:
014 - Defective
Coding: 0000107
3 Faults Found:
000 - -
Coding: 0000173
2 Faults Found:
Coding: 0012368
Coding: 0000212
Coding: 0021400
Coding: 0000006
Coding: 0015500
1 Fault Found:
Coding: 0000002
2 Faults Found:
Coding: 0400000
Coding: 0000157
Coding: 0000032
2 Faults Found:
Coding: 0022413
Coding: 0000010
Coding: 0011344
12 Faults Found:
006 - Short to Plus
When you say “ the car drives beautifully ....” does that mean the parking sensors and seat positioning motors etc all work and you detect no faults what so ever despite the codes suggesting otherwise?.....AND all those bulbs work , they are not out !
2- state of the LHS battery ? .....voltage and if it’s been left without a trickle charger .....if so a voltage drop = throws codes like confetti at a wedding .
hi buddy ,
did you get to the bottom of this? mine throws up this code but implausable signal p2587-008 ?
Hi sorry for really late reply I've not been on here for a while. The answer to your question is no I haven't how did you get on with yours
