I think it's a vacuum leak :(
Old 01-31-2020 | 10:53 AM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
You found yourself a keeper with that tech. Buy his garage lunch and gatorade, he's extremely reasonable. I think I paid almost that much just to get my third brake light replaced.
Old 10-05-2021 | 09:06 AM
CarshowRell's Avatar
CarshowRell is infamous around these parts
Originally Posted by Barry DeWitt
Rosso Service in Maryland.
Just called Rosso today for my F/S. I have the dreaded vacuum leak. Great news to know this most likely isnt a engine out job. AT LEAST I HOPE
Old 10-05-2021 | 02:00 PM
Barry DeWitt's Avatar
Barry DeWitt is infamous around these parts
Best of luck! What year and how many miles on your Spur?
Old 10-05-2021 | 03:20 PM
2006 112k had her since 49k many many many years ago lol
Old 10-08-2021 | 03:31 PM
silvertonesx24's Avatar
silvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud of
All flying spurs have the new vac lines that aren't over the transmission, so if you want you can bypass the steering rack lines and run a copper bypass line underneath the engine. 3-4 hours or so of work and maybe $50 or less in parts.
Old 12-17-2021 | 01:11 PM
jking702's Avatar
jking702 is infamous around these parts
Bentley vac lines
What year and model is your Bentley? I may be having the same issue and was wondering if my lines run a cross the transmission.
Originally Posted by British
I had a very similar experience. I had them change the plastic lines for stainless, but the check engine light came on, so I was headed back to the specialist. At the toll booth, I really launched it and popped off a vacuum fitting. The traction control light came on and it started idling horribly. I took it in, they found the loose fitting and reset the computer, everything was fine. I asked them how in the hell could the vacuum system have anything to do with the traction control...they shrugged their shoulders and said that Bentleys often had interconnected computer error messages for one problem.
Traction control light never came on again and vacuum lines are fine.
If you need the vacuum lines, get the stainless ones, not the plastic ones. I spent $1,200 but right after someone said there is a guy who bends them for $200, which seems a fair price. $1,200 was a ripoff.
Bad news: 33 hours of labor to pull the engine and replace it. Depending on your model and year, you may get away with less, I don't know much about the Flying Spur differences. I think your plastic lines still go across the transmission though.
Old 12-21-2021 | 05:01 PM
British's Avatar
Mine's a 2005 GT.
Johnny pointed out that I didn't really get stainless lines, they were just plastic with foil, which is a drag. I don't know if stainless is a Bentley option, there's some guy that sells handmade ones.
The way you know you have a bad vacuum leak is that the car idles really poorly, it will stay running, but 500 rpm then 1,500 rpm, then 500 again. it sounds just terrible.
Post a video of your tachometer at idle.
Old 12-21-2021 | 05:18 PM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
If I’m not mistaken, I think he went up in price. I’ll confirm in a few days just to make sure.
ULSTRUP
Bentley
23
04-23-2017 07:27 PM
JustinCase
01-03-2016 03:39 PM
f1crazydriver
11-06-2013 09:27 AM
007-911
07-19-2009 06:56 PM
Quick Reply: I think it's a vacuum leak :(
