05-06 Bentley GT or S65 AMG
Old 01-28-2020 | 08:40 PM
MBi's Avatar
MBi
MBi is infamous around these parts
Completely different car but you can buy a good earlier 2015 Quattroporte or a GranTurismo CPO if you want lower maintenance around 1-3K per year at a independent. 14 GT Sport Convertible has been great only time a belt snapped was when dealer forgot to change it along with a broken mirror switch, driver mirror, interior trim was broken by dealer but repairs were reasonable. Otherwise has been reliable no CEL's. Goes through front tires around 8K and rear 5K get the Michelin PS4S and they last longer while performing better.
Old 01-29-2020 | 07:08 AM
Ryan...'s Avatar
Ryan... is infamous around these parts
Never been a fan of the Quattroporte, the Gran Turismo is a beautiful car, but likely not what I'm looking for either at this time.
Old 01-30-2020 | 11:14 AM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
AWD V8 Jaguar convertibles/coupes are also a great looking / fun car that depreciates nicely!
Old 01-30-2020 | 11:25 AM
RobJLR's Avatar
RobJLR is infamous around these parts
Very reliable cars for the money as well.
I'd at the very least test drive an F-Type V8, not because it is similar but because it is such a hoot to drive-
The XJ575 or XJR is also a very comfortable super saloon with 500-575HP to the rear wheels, mine was incredibly reliable but the quality doesn't compare to Bentley.
Old 01-30-2020 | 01:52 PM
sam08861's Avatar
as far as the s63 taxi....
couldn't find a legit Bentley taxi quickly on a google image search, but I'm sure they're out there.
edit... found it.... Of course, it's Dubai, so even lambos, RR, etc aren't immune from being put into 'car slavery'
http://english.alarabiya.net/en/vari...ari-boost.html
Old 02-01-2020 | 07:05 AM
W. M. Hellinger's Avatar
W. M. Hellinger is infamous around these parts
Originally Posted by skilly
I had a burned out DLR on my car....it was an eye opener to consider replacing the burned bulb.
Here is a picture...before anyone jumps all over being able to avoid this work I would only ask if they were replacing the DLR and/or turn signal AND they were able to get to the passenger side AND re-secure the enclosures for the light assembly to protect the housing from road debris and the weather. it *might* be possible, but Im pretty confident that its a 1 in 100 shot at getting it all down without a problem.
To do it right its either what you see here, or start tearing down the engine/air intake (which i am not confident would produce enough space to get to them either).
I'm working on removing the left headlight housing on my '08 GTC as it needs changed due to damage to the existing housing. I'm at the point you were at in your picture, and with that I have a question: If you removed the headlight housing, do you have a tip on getting the darn electrical plug unplugged from the housing? Mine is being really stubborn. I have the retainer clip unclipped, but absolutely cannot get the plug out of the socket... it's like it's glued in.
Old 02-01-2020 | 11:01 AM
Update: I figured it out and successfully disconnected the headlight connector: I remembered I happened to have a spare wiring harness and was able to get a good look at the headlight plug, and as it turns out, I didn't have the lock-tab released. To release the lock tab, depress the exposed end of the tab, which has a rectangle relief cast in it. The lock tab is internal, and is thin plastic... it's hard to get it to released... push in on the connector body while depressing the exposed end of the tab. Depressing the exposed end of the lock tab lifts the internal portion up off the catch. The rectangle relief in the release tab seems specifically designed for leaving an impression in your finger if you depress it hard enough to do the job. Just getting to the release tab is difficult for one hand... virtually impossible to get both hands into the action... I wish the wiring pigtail going to the headlight connector was a few inches longer.
Matthew Manaloto
Bentley
18
01-29-2020 10:19 AM
ek1
Bentley
32
06-18-2015 06:36 PM
porsche23
06-22-2009 09:22 PM
Hainz
07-27-2007 04:19 PM
Denstoyz
12-26-2006 01:40 PM
Quick Reply: 05-06 Bentley GT or S65 AMG
