Someone knowledgeable please answer vacuum tube model year question?
Johnny, would you happen to know the correct name or the part number for that valve/solenoid? I want to look it up and maybe buy one and have it on standby with the hoses. I know damn well it’s not $900!
There are also two other solenoids re: n75 which are the turbo wastegate solenoids, different part number.
Pierburg - Valve Control Solenoid (N249) - 078906283A | eBay https://www.ebay.com/itm/Pierburg-Va...-/232691655129
I take it by solenoid/valve you mean the purge valve as shown in your attached quote at $900
I found these, it's one or the other as the vehicle only has one purge valve.
JJJ
Also, in the pictures you have with the yellow circle, is this that part?
I see it a VW part so I’m going to cross reference to see if it’s cheaper elsewhere.
Also as to the purge valve, do not bother yourself looking up the numbers shown in my pictures, the "058 133 459" is just the part number for the rubber holder of the purge valve, and the "PA66-GF-30" on the purge valve itself is just the number for the type of plastic it is made of.
Johnny
Johnny
Hello TJ,
No, the purge valve is not in the yellow circled area, the "purge valve" as your quote calls for is located in the passenger front area next to the coolant reservoir tank.
I get a picture in a few.
I agree, you could probably pick one up of Ebay for $25-$50, my Audi A8L W12 has the same unit.
Johnny
Johnny
