VCDS cannot read auto transmission?
Any reason why VCDS can't see the gearbox? It reads other modules fine. Does it report "Address 02: Auto Trans
Cannot be reached" if there are no errors?
Just saw your PM and.
I meant to respond to this last night after I asked my son if he had ever heard of this, and his answer was that one of his Audis did the same thing, it turned out to be a defective ABS control module on the ABS unit under the bonnet, when he unplugged the ABS module the VCDS would then read the transmission, VCDS reads my Audi A8L W12 as the ABS C/M being "DEFECTIVE" yet all works fine, and also reads my transmission with no problem, Yet, my Son's Audi was reading the ABS C/M as good, but would not read the transmission, somehow he came to the idea of unplugging the ABS and then his transmission was able to be read... Strange .
Hello Rich,
I meant to respond to this last night after I asked my son if he had ever heard of this, and his answer was that one of his Audis did the same thing, it turned out to be a defective ABS control module on the ABS unit under the boot, when he unplugged the ABS module the VCDS would then read the transmission, VCDS reads my Audi A8L W12 as the ABS C/M being "DEFECTIVE" yet all works fine, and also reads my transmission with no problem, Yet, my Son's Audi was reading the ABS C/M as good, but would not read the transmission, somehow he came to the idea of unplugging the ABS and then his transmission was able to be read... Strange .
The scan is showing something odd on the ABS too...
Thursday,13,February,2020,17:35:21:24880
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: SCBCF63W88C058594 License Plate: FINAL SCAN
Mileage: 101750km-63224mi Repair Order:
Chassis Type: 3W (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 34 36 37 38 46 47
53 54 65 68 71 76 77
VIN: SCBCF63W88C058594 Mileage: 101750km-63224miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
54-Rear Spoiler -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine ( ) Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 FQ HW: 07C 906 018 FK
Component: BY- 6.0L -TT NC G �1932
Revision: --H03--- Serial number: VWX3Z0H3750512
Coding: 0001175
Shop #: WSC 00083 790 00000
VCID: 79AFEA8B55CF41CF8EB-5160
No fault code found.
Readiness: 0110 1101
Cannot be reached
Address 03: ABS Brakes Labels: None
VCID: 55F7863B9D4745AFCA3-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 D HW: 5WK 485 05
Component: 74 Kessy 6840
Revision: 68406620 Serial number: VWX3Z0H3750512
Coding: 0422125
VCID: 2809FFCFFEB50847A15-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 C
Component: CM Seat Pass. 0018
Coding: 0000001
Shop #: WSC 30646 002 1048576
VCID: 49CF5A4B45FF114F5EB-801C
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 007 Q
Component: ZAB COCKPIT 2215
Coding: 0400327
VCID: 3A2D358710498AD7C71-5160
1 Fault Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 F
Component: Climatronic BY614 2014
Coding: 0000111
Shop #: WSC 00000 000 00000
VCID: 34311BBF327D7CA71DD-8060
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 M HW: 3D0 937 049 M
Component: J519 6500
Revision: -4004--- Serial number: --------------
Coding: 40020000AB2A11000000000000000000
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Coding: 0001175
Address 15: Airbags Labels: None
Part No SW: 3W8 909 601 HW: 3W8 909 601
Component: 15 Airbag 9.41 H14 0040
Revision: 91H14004 Serial number: 0039L000AVE2
Coding: 0012597
VCID: 7BA3F0835FA373DF9C7-802E
Subsystem 1 - Serial number: 63328RB403A6D593R
Subsystem 2 - Serial number: 63428RB403A68F07S
Subsystem 3 - Serial number: 63528RB403A6D5BB$
Subsystem 4 - Serial number: 63628RB403A68F0D-
Subsystem 5 - Serial number: 63700RB4 I
Subsystem 6 - Serial number: 63800RB4 J
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 L
Component: J527 3601
Coding: 0000232
VCID: 48C95F4F5EF5E847415-801C
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No SW: 3W0 920 841 E HW: 3W0 920 841 E
Component: J285 KOMBI-INST. 1623
Revision: K0H10V35
Coding: 0005402
Shop #: WSC 01179 210 93569
VCID: 372B2CB3234B97BF38F-8062
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3W0 920 841 E
Component: J533 GW-K-CAN TP20 1623
Coding: DFF8FF2E170E4701
VCID: 70B9D7AF06A50087395-8024
Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W0 907 553 E
Component: LUFTFDR.-CDC- 3C3V0 7213
Coding: 0005571
VCID: 3C21339F1A2DB4E7D5D-8068
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 C
Component: CM Seat Driver 0018
Coding: 0000001
VCID: 41DF426B7DCFD90F86B-8014
Address 37: Navigation Labels: None
No Faults Found
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 F
Component: Dachmodul 0802
Coding: 0006589
VCID: 392F2A8B151F81CFCEB-806C
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 H
Component: 0P HSG 0200
Coding: 0000040
Shop #: WSC 54455 002 1048576
VCID: 353726BB395765AF2A3-4B00
Subsystem 1 - Part No: 3W8 959 701 J
Component: Tuersteuergeraet FS 1106
Subsystem 2 - Part No: 3W8 959 702 J
Component: Tuersteuergeraet BF 1106
Subsystem 3 - Part No: 3W8 959 703 D
Component: Tuersteuergeraet HL 0703
Subsystem 4 - Part No: 3W8 959 704 D
Component: Tuersteuergeraet HR 0703
Subsystem 5 - Part No: 3W0 909 610 H
Component: 14 HDSG 2013
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
1 Fault Found:
01816 - Exterior Door Handle Switch in Drivers Door (F272)
007 - Short to Ground
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W8 035 456
Component: 12K-AUDIOVERST 3000
VCID: 79AFEA8B559F41CF8EB-802C
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 H HW: 3W0 907 801 H
Component: EPB BC7H0300 HC7 0300
Coding: 0022413
Shop #: WSC 58237 002 1048576
VCID: 3B2330831F73B3DFDC7-5160
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 303917AFC3354087795-51A8
Address 65: Tire Pressure Labels: Redir Fail!
Part No SW: 3W7 907 273 A HW: 3W7 907 273 A
Component: J0502 RDK 0004
Revision: 0004 004 Serial number: 00000700004300
Coding: 3501E052A5F9A5A5F9A7DA00A7DA00
VCID: 3E2539970C31A6F7FB9-806A
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W2 955 023 G
Component: Wischermodul �9328
Shop #: WSC 00000 725 65552
VCID: 3B2330831F23B3DFDC7-806E
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 2411EBFF829DEC278DD-8070
Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283 B
Component: 0C Einparkhilfe 0404
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 AS HW: 3W0 035 385 AS
Component: rSAP Bentley 0262
Revision: 00008000 Serial number: 30800000056451
Coding: 0031000
VCID: 0655917714613E37F39-8052
End----(Elapsed Time: 02:37, VBatt start/end: 12.0V/11.8V. VIgn 11.8V)-----
JJJ
It's odd because I could scan an 06 car no problem but I had to set this to read my 09 car. The ABS in the 06 car is Bosch 5.7 and the one in the 09 car is 8.1
I would be calling Ross-Tech for an answer on that.... Very strange.
a10033208
12-10-2011 07:38 PM
