2011 GTC Power seat issue recline only
Old 03-15-2020 | 05:21 AM
Gillis51's Avatar
Gillis51 is infamous around these parts
I tried to recline my passenger side seat the other day and it would move recline. It moves in every other direction just not recline. I tried my drivers seat and same deal. Seat moves in all directions except recline.
I can’t imagine a separate fuse controls recline and that would also be a separate relay for recline function. Anyone have a suggestion.
Old 03-15-2020 | 11:23 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @Gillis51,
I believe you meant to say that the seat "would (not) move recline" in your first sentence.
So tell us if you move either seat's backrest to a forward un-reclined position, can you then recline each back to the normal driving position, I am thinking, and this is just off the top of my head, that if both seats behave in this manner, does the convertible have a safety switch/micro switch somewhere for when the rear seat wind/air screen is in place, therefore not allowing the reclining of either seat.
Johnny
Old 03-16-2020 | 04:27 AM
Gillis51's Avatar
Hello @Gillis51,
Johnny
You are correct, it is supposed to read “Not recline”
Ive moved both seat backrests to forward “not reclined” and no nothing. I’ve inclined the backrest of the passenger side fully and now it’s stuck.
ive checked all fuses again and all are good.
I did see a video on YouTube about recalibration seats with Vag-Comm. i assume its with Ross Tech. Any suggestions
Old 03-16-2020 | 08:58 AM
Administrator
Hello Gillis,
Have you had any issues with the batteries at all ?
Have you tried removing both negative cables from the batteries for a reset, after you will need to readapt the windows and seats, no tools needed, just putting the windows up and down in a sequence, same with the seats.
As to the Ross-Tech, yes, it is a great tool to have, as is the VAS 5054, with the RT you would get seat fault code, clearing of fault code, switch testing etc.
Johnny
Old 03-16-2020 | 09:15 AM
Gillis51's Avatar
Thanks Johnny
are there any other concerns that come along with disconnecting the batteries? If not I’ll try that today.
what are the differences between the two tools. The Ross tech costs $449 bs under $100
Old 03-16-2020 | 09:42 AM
Administrator
Thanks Johnny
Facing the rear of the vehicle, remove the right side starter battery negative terminal, next remove the left side house battery negative terminal, leave off for maybe an hour, then hook up in reverse order, left on first, then right.
You did not answer as to any issues with the batteries at all.
Also I do not understand "bs under $100"...
Johnny
Old 03-16-2020 | 09:58 AM
Gillis51's Avatar
I’ve had the car since early January no issues with batteries since ownership.
bs should have been is. My iPhone changes words automatically and my eyes are not as good as they used to be
there is a fairly large difference in cost between the two units. Does one have an advantage over the other
Old 03-16-2020 | 10:52 AM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
If I’m not mistaken, the $100 you can only register 3 to 10 cars. The $599 one is unlimited. That’s the top advantage to me.
Old 03-16-2020 | 11:16 AM
Lars_Tempest's Avatar
Lars_Tempest is infamous around these parts
Hi Gillis,
If you look at the thread under yours there is a fairly detailed discussion on a problem I had with my GT, and turned out to be a faulty control unit. The unit sits under one seat (the RH drivers on my UK car).. It could be a similar problem, who knows..
Good luck!
Old 03-16-2020 | 12:05 PM
Administrator
Originally Posted by Lars_Tempest
Hi Gillis,
Good luck!
Hello Lars,
You are correct it could be the modules, but as there is a module under each seat, it is very odd the each module under each seat would fail for the same issue at the same time, even having the same recline switch fail for reclining at the same time would be odd.
Lets see what after a battery disconnect.
Gillis,
Can you tell us the age of the batteries, are they the originals, 8-9 years old ?
Johnny
Old 03-16-2020 | 04:31 PM
Gillis51's Avatar
I disconnected the batteries for about 20 minutes and no change. Doing it again for longer time.
Also noted the traction control light is now on and won’t turn off if button is pressed.
The battery on the left (facing back of car) is an interstate 49/H8 the one on the right appears to be Original as it says Volkswagen original batterie. The one on right has one of the green eyes that glows when battery is bad. This one indicates batter is fine.
don’t see a date sticker anyplace on either and don’t want to move them unless I need to replace. The
Old 03-16-2020 | 05:01 PM
Administrator
The TCL will go off when you drive the vehicle around the block.
Old 03-16-2020 | 05:56 PM
Gillis51's Avatar
I figured traction control will turn off. What are your thoughts on batteries and impact on my seats.
Old 03-17-2020 | 02:29 PM
Administrator
As far as the house battery (left side) that has been replaced, but when, there should be a little round sticker with the month and year on the battery, Have you had to use the emergency CCW turn of the key to start the vehicle at all ?
Next I would get the Ross-Tech for a scan of the seats, what is your location, so if someone here is close to you to maybe help with a scan if they have the RT.
Johnny
Old 03-17-2020 | 04:39 PM
Gillis51's Avatar
Problem solved but not entirely sure how I rectified the issue.
I left negative terminals off both batteries overnight (approx 24 hours). Put terminals back on and started the car. This did not resolve the seat issue.
I then moved seat all the way forward and then backward the. Seat all the way up then all the way down. Still nothing.
I then moved seat lever forward to allow someone in back seat so backrest was in most forward position. Then I moved seat all the way back, and lowered it as low as it would go. Then moved seat lever back as though in normal driving position. At this point the recline button started working again.
So seems there are some odd quirks with these cars. Very happy to have my sweets in comfortable position again and likely will never touch them again.
thanks for all the suggestions and help
BTW I am south about 20 miles of Boston Ma if anyone is in the area.
Arthur
Quick Reply: 2011 GTC Power seat issue recline only
