Shifter Plate Problem?
I'm guessing this is not correct? When the shifter is moved out of the Park position should the black surround plate fill the space above the shifter? Currently I can see down into the shifter linkage.
Thanks.
Thanks.
search the forum for "plastic shifter slider thing" 'British' supplied a valid link for a replacement part for `$60!! Unless i'm confused of your issue. Johnny even posted how-to pics on the replacement procedure.
I bought one, haven't installed it yet, but it looks identical to the Bentley part.
https://www.6speedonline.com/forums/...g-cover-2.html
As far as not feeling it, it is probably all the way down in it's slot.
Johnny
