Battery maintainer
Old 03-23-2020 | 07:16 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Battery maintainer
I have a 2014 Flying Spur. It has the factory battery maintainer that connects via a magnetic plug on the outside of the trunk.
I plugged it in at the car and then plugged it in to the wall outlet. It now blinks between two red lights. What am I doing wrong or is it defective? I tried the maintainer from my Aston Martin and it seems to be working. Thanks for any help.
Old 03-24-2020 | 07:04 AM
Rottboy's Avatar
Rottboy is infamous around these parts
I'd clean contacts to eliminate the simplest problem first. Have you tried the Bentley charger on the Aston? They are both rebranded CTEK's and should give you an indication if both chargers are functioning the same.
Old 03-30-2020 | 04:03 PM
biswajitdg's Avatar
biswajitdg is infamous around these parts
I use the charger and get this issue once in a while. I unplug the power cord for 30 seconds and press the reset key for a couple of seconds. it works fine after that.
Hope that works for you
Old 03-30-2020 | 04:14 PM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
Had this happen on an older BCGT with the older plug in style, inside the trunk.. Was a 20A fuse on top of the battery, which wasn't listed anywhere in the owner's manual.
Thom Morrow
12-08-2019 07:54 PM
Antigravity Batteries
09-11-2019 08:46 PM
Rohmot1961
10-09-2018 04:52 PM
Dr P
08-06-2016 03:20 PM
yo-lily
02-27-2016 04:10 PM
Quick Reply: Battery maintainer
