Sirius tuner location 2010 GTC
I’ve been trying to figure this out for a long time. My GTC satellite radio doesn’t work. Screen says antennae problem, so I replaced the antenna module under the trunk lid. No change. The Ross Tech scan doesn’t show the module, or it doesn’t see anything at 1F. So I’m thinking maybe I should try a used tuner . I’ve seen them on EBay pretty cheap. I know on the GT it’s located under the package shelf, but anyone know the location on the convertible? I need to check for power first, but didn’t want to start tearing apart the trunk trying to find it. Thanks!
iirc it’s under the parcel shelf (rear deck). It’s a few post on here that touches on it. Try to search and dig through what comes up.
Edit:
https://www.6speedonline.com/forums/...o-antenna.html
Edit:
Here you go.
"C01153"
Johnny
