Changing interior light to LED
Old 05-22-2020 | 10:36 AM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Originally Posted by TungNguyen
Thanks a lot, hopefully someone can help me. I have check fuse manual and it seems that there is only one fuse #35 for all interior lamps.
I haven’t read this entire thread but maybe it’s the actual switch that’s bad.
Old 05-22-2020 | 11:01 AM
TungNguyen's Avatar
TungNguyen is infamous around these parts
I don't think the switch is bad because when I press the button, two lamps under the front seats are still on. Only courtesy lamp is not working.
Old 09-28-2020 | 12:23 AM
Hayssam's Avatar
Registered PM
Hayssam is infamous around these parts
hi TungNguyen thank for the info. that you have provided i was planning to do the same for my car but was just waiting for someone to direct me in the right way so now correct me if i am wrong or missing something
I need following to change all the lights in my car to LED`s
3 -36mm for the courtesy lamp
2 -T10 for the reading light
4 -36mm for the license plate
2 - 36mm for the trunk
4 - 194 for the door
FlyYellow
10-16-2016 08:15 PM
liuxiaoyu
Cayenne 955/957
11-25-2011 03:33 PM
bjarne996
01-04-2010 10:31 PM
C2SKID
09-29-2008 05:03 PM
Quick Reply: Changing interior light to LED
