Changing interior light to LED
Old 05-18-2020 | 09:24 AM
TungNguyen's Avatar
TungNguyen is infamous around these parts
Changing interior light to LED, rear courtest lamp not working
Update: My rear courtesy lamp is not working. When I push the button only 2 lamps under the bottom of the front seats work. I also turn on the door open switch, when door is open, only 2 lamps under the front seats work, the rear courtesy lamp is still off.
What do you think?
Following the instructions on this topic:
https://www.6speedonline.com/forums/...onversion.html
I finally managed to change all the halogen bulb to LED.
The reading lamp is T10 type bulb and courtesy lamp has 3 36mm festoon type bulbs.
Here is the short clip showing how to open the lens of the reading and courtesy lamps.
The white LED makes car look pretty cool
Many thanks!!!
Old 05-18-2020 | 09:52 AM
TungNguyen's Avatar
I found the way to change the ceiling light here:
This forum is great!!!
Old 05-18-2020 | 10:54 AM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Don’t forget the 4 at the license plate and the 2 in the trunk! 😁
Old 05-18-2020 | 06:00 PM
TungNguyen's Avatar
yeah I changed all the door light, licence plate, side mirror, day running light as well as 4 in the trunk
Old 05-19-2020 | 03:24 AM
TungNguyen's Avatar
Today I followed the instruction and it's much easier than I thought. The front lights are okay now. I got problem with the rear middle lamp (bigger one), I can't turn it on. Where can I find the fuse for this one? Many thanks!!!
Old 05-20-2020 | 06:41 AM
TungNguyen's Avatar
Can anyone please help me on this one:
I can turn on 2 rear reading lamp but not the main rear ceiling lamp. When I push the button, only two lamps on the bottom of the front seats are on. Normally these 2 lamps and the main rear ceiling lamp should be on.
I tried to open to wood trim and everything looks just fine, no broken wire or switch. Should I check a fuse somewhere?
Old 05-20-2020 | 06:54 PM
BentleyF's Avatar
BentleyF is infamous around these parts
put bulb in the opposite way. the polarity is wrong. try putting in stock bulbs andn see if it works.the led bulbs will only let current flow in one direction.
Old 05-20-2020 | 07:03 PM
TungNguyen's Avatar
Thanks for your feedback.
All bulbs are still original halogen type and I took them out to test and 3 of them work well. Because the main lamp is not working so I haven't change to the LED yet.
FYI, the LEDs I am using can automatically switch polarity so we don't have to worry about it, you can plug them in anyway and it will work pretty cool
Old 05-20-2020 | 07:07 PM
FYI, the LEDs I am using can automatically switch polarity.
Huh????????????? Y’all joking right?? 🤣
Old 05-20-2020 | 09:50 PM
TungNguyen's Avatar
haha no, I'm not, check this video I just shoot
Old 05-20-2020 | 11:32 PM
shorttough's Avatar
shorttough is infamous around these parts
are these canbus led lights? meaning they have resistance built into them. i think i had the same problem.
Old 05-21-2020 | 04:49 AM
TungNguyen's Avatar
I think so. Your rear courtesy lamp is not working, too?
Old 05-22-2020 | 06:19 AM
TungNguyen's Avatar
Anyone ? 😁
Old 05-22-2020 | 06:45 AM
Sorry, I don’t have that rear overhead like you all do. I just have a single light in the headliner in the back which works as it should after I changed the bulb.
Old 05-22-2020 | 10:16 AM
TungNguyen's Avatar
Thanks a lot, hopefully someone can help me. I have check fuse manual and it seems that there is only one fuse #35 for all interior lamps.
Quick Reply: Changing interior light to LED
