Bentley Supersport won't chime when locking...any suggestions??
Old 07-16-2020 | 07:04 AM
Gianni Perrotta's Avatar
Gianni Perrotta is infamous around these parts
Exclamation Bentley Supersport won't chime when locking...any suggestions??
Hi - I was wondering if anyone knew how to activate the chime/chirp feature when locking/unlocking bentley Supersport or Continental GT should be the same...thanks in advance for your guidance.
Old 07-17-2020 | 02:07 PM
cerex's Avatar
cerex is infamous around these parts
should be everything you need.
I did this yesterday by the way to my car
https://www.6speedonline.com/forums/...ip-coding.html
Old 07-17-2020 | 02:29 PM
i'm not sure I understand, am i suppose to follow a sequence to activate the chime/chirp?
Old 07-17-2020 | 02:43 PM
cerex's Avatar
Need interface and software to connect to you car reprogram the setting to chirp when you lock/unlock your car.
I personally purchased this interface https://store.ross-tech.com/shop/vchv2_ent/ downloaded the software on my Windows based laptop and make the coding changes to my car (Post #9 from Peter) in the original link I sent
You basically need VCDS to interface with you car to make updates to the settings.
great tool for diagnostics and other things you can do to change settings to the car, it is almost dealer quality diagnostic and programming capability
Otherwise you can have the dealer do it but it needs to be an ODB2 connection made to you car with programming capabilities
Old 08-20-2020 | 11:25 AM
Nader's Avatar
Nader is infamous around these parts
tonygt63
Bentley
09-11-2016 03:21 PM
oholowes
Bentley
05-16-2014 04:39 AM
PCH
Bentley
05-06-2009 02:56 PM
alamein
Bentley
09-10-2003 03:40 AM
Quick Reply: Bentley Supersport won't chime when locking...any suggestions??
