how to remove steering wheel 3 spoke
Old 07-31-2020 | 11:37 PM
yanacha's Avatar
yanacha is infamous around these parts
Hello, My friends
how to remove steering wheel bentley continental gt 3 spoke for supersports 2011.
Old 08-01-2020 | 04:06 PM
AJ1's Avatar
AJ1
AJ1 is infamous around these parts
Here you go ....
Old 08-02-2020 | 05:46 AM
cerex's Avatar
cerex is infamous around these parts
You don’t need to dissemble the entire column
Old 08-02-2020 | 07:54 PM
Johnny Hotspur GT's Avatar
Administrator
​​​​​​Hello @cerex ,
I was about to say the same yesterday, BUT, after looking at the rear side of the airbag and the backside of the steering wheel itself, the 3 spoke wheel does not have the 2 holes in the leather to insert a flathead to turn and release the airbag like the 4 spoke wheel does, and the 3 spoke airbag does not have the same locking setup as the 4 spoke, meaning even if you poked the 2 holes in the leather (because the 2 holes are still in the steering wheel itself, but covered by leather, unlike the 4 spoke) the flathead would not release the airbag because the locking rods/pins are different on the 3 spoke, so it looks like taking the upper and lower covers off of the column is correct.
Johnny
Old 08-02-2020 | 08:11 PM
Administrator
This is the 4 spoke airbag locking setup, where you would turn the steering wheel to expose the 2 hole on the backside of the steering wheel itself, and insert tool to release the airbag.
Johnny
Old 08-02-2020 | 08:23 PM
Administrator
This is what the 3 spoke steering wheel looks like, no holes in the leather, but holes in the SW itself, but they seem to be useless, then the airbag showing the difference in airbag locking clips.
Johnny
Old 08-02-2020 | 08:32 PM
Administrator
Or is it that one would place a flat tool in each side to release the 3 spoke airbag without disassembly of the steering column covers as @cerex stated ??
Johnny
Old 08-02-2020 | 09:22 PM
cerex's Avatar
I was confused by this when I got my new 3-spoke wheel (which I have not yet installed - i will post pics) but i have figured out you don't need to remove the steering wheel column.
Unlike the 4-spoke that is turned upside down (180 degrees) to release the 2 screws, the 3 spoke wheel needs to be turned to a 90 degree angle and you use a flat tool to push clips inward and unclip one side at a time. Will need to rotate the wheel to that 90 degree angle for each side.
Apply pressure to the 3-spoke air bag as if you are honking while doing the unclipping procedure to help relieve with the pressure/tension of the rear clips.
There is also several fuses that need to be pulled (airbag fuse, horn fuse, motor function fuse for the steering column)
Old 08-02-2020 | 11:54 PM
yanacha's Avatar
Thank you for theses precious informations. So it’s possible to dismantle with a flat screwdriver a little twisted without dismantle everything ?
Old 08-03-2020 | 06:28 AM
cerex's Avatar
Yes.
I verified it in the Bentley Technical service manual yesterday. Just angle the wheel the correct way and you will be able to unclip the bag one clip at a time
Old 08-08-2020 | 04:57 PM
cerex's Avatar
3 Spoke Wheel Conversion
Saturday project completed
Hardest part was getting the 4-Spoke Airbag off once that was done smooth sailing. The reference pictures above are spot on thank you helps to know which way to turn the screw driver. If your going to do this have an L shaped flat head screwdriver available and save yourself the headache.
One item I haven’t seen posted was have a 1/2 inch T-55 torx bit on hand to remove the steering wheel bolt. It is also suggested not to reuse the bolt and use a new one but I didn’t have one handy so went with the old one. New one is $6.00 if your planning a conversion order one part # N90799101 (bolt).
I disconnected both batteries Right starter side first, left Main one second (negative leads only). Waited 30 minutes before getting the airbags and wheels swapped. Better safe than sorry, she woke up with no issues after the install was complete - all faults went away after a short drive. Seat memories retained windows needed to be reprogrammed.
Just need to now program the cruise control buttons the others all work, but my kids and wife are out of patience for today.
Going from the wood 4-spoke wheel for the sporty 3-spoke one is night and day visually and steering feels completely different much more responsive feel.
Old 08-08-2020 | 05:07 PM
AJ1's Avatar
AJ1
Great job, looks so much better than the old one. Can I ask where you purchased the new one from and what you paid for it ?
Old 08-08-2020 | 06:18 PM
cerex's Avatar
Got it from a contact in Latvia as a complete set with hub and airbag.
All in $2500 + $4.29 for a T-55 torx bit
I will also get hit with some duties from Fedex, but wont be too bad for the import 40-50 USD to New Jersey.
nguyennhatquang
Bentley
07-10-2019 07:14 AM
cduluk1
Bentley
01-23-2016 09:34 AM
REDNOSEGT
Bentley
04-29-2013 08:15 PM
Wazeemu
Bentley
09-04-2010 10:04 AM
my996
08-02-2010 07:29 AM
Quick Reply: how to remove steering wheel 3 spoke
