'06 BCGT Brakes
Old 08-25-2020 | 06:25 AM
jslamin's Avatar
jslamin is infamous around these parts
'06 BCGT Brakes
Can anyone definitively tell me what non-Bentley rotors and pads fit the '06 BCGT? Front and rear. The PDF service manual, found elsewhere on this forum is vague on the topic.
Old 08-25-2020 | 07:37 AM
silvertonesx24's Avatar
silvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud of
I just did this. I didn't do the rears but those are A8 rotors and pads and available everywhere. You need a obd tool to release the parking brake. The front rotors are more limited but can be found aftermarket at rockauto. I just installed them and they work fine.
Old 08-26-2020 | 05:45 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @silvertonesx24 ,
As to not confuse others, please list the part numbers and or size of the front brake rotors and pads you purchased, as the standard A8 (D3) 4.2 has smaller brakes all around, with 360MM X 34MM in the front, and 310MM in the rear, whereas the A8L W12 and the S8 5.2 V10 have the larger brakes being 385MM X 36MM for the front, and 335MM for the rear, IIRC.
And our generation GT'S have 405MM X 36MM for the front, so I am not sure how you used "A8" rotors, unless I read your comment the wrong way...
Thanks.
Johnny
Old 08-26-2020 | 06:54 AM
Administrator
Here are some listings from Scuderia.
Front rotor.@$490ea.
https://www.scuderiacarparts.com/par...rake-disc.html
Rear rotor. @$150ea
https://www.scuderiacarparts.com/par...reak-disc.html
Alpine has the front in OEM aftermarket at $350ea.
https://www.alpineperformance.com/be...isc-rotor-4282
Old 08-26-2020 | 09:46 AM
This is the front aftermarket rotor I used. $83 each. I can't remember specifically which pads I used, but they came with the wear sensors.
https://ebay.to/3lnTguA
I actually did not replace the rear rotors yet, they didn't seem too bad and the front ones were very worn and warped. But from my research sellers were also listing the A8 Quattro in the compatibility description. They are much, much easier to find than the front rotors.
Old 08-26-2020 | 10:05 AM
ronnie1956's Avatar
ronnie1956 has a spectacular aura aboutronnie1956 has a spectacular aura about
Brakes
only use Bentley discs on front Will buckle if use cheap ones
plus your insurance will be void!!
Old 08-30-2020 | 12:09 PM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
​​​​​​​What do you mean the front will buckle? That they will warp more than OEM?
And by insurance being void, do you mean warranty? Or are you saying car insurance will be voided for aftermarket parts?
Old 08-30-2020 | 12:21 PM
ronnie1956's Avatar
Brakes
my garage told me that using cheap disc that they will buckle after a bit because of the heat that’s generated, also this car can do over 190 mph and if you put cheap disc on it you can void your insurance, ask your insurance company, To make sure. Also the tyre are rated for this speed. Just check.
Old 08-31-2020 | 12:28 AM
joc44's Avatar
joc44 is infamous around these partsjoc44 is infamous around these parts
I fitted rear discs last year from Shrewsbury audi with part number 4E0615601L Audi 8 335x22mm with 50% off payed just £90
Old 09-07-2020 | 05:51 AM
jslamin's Avatar
Thanks Johnny. I know about Scuderia. They have everything but are pricey, and shipping is not included.. There is also Flying Spares in the UK, which with shipping may be less $ than anything in the US.
silvertonesx24
Bentley
07-21-2020 09:30 AM
King James
02-02-2015 01:30 PM
Bruin Pcar
Cayenne 955/957
17
11-30-2010 09:43 PM
Quick Reply: '06 BCGT Brakes
