Aftermarket parts?
Old 09-14-2020 | 11:09 AM
Linescreamer's Avatar
Linescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud of
Aftermarket parts?
Where do you guys buy your parts? Getting parts here in NJ from a dealer is like buying a Picaso!
Old 09-16-2020 | 11:35 AM
Wow! 151 views and not 1 response? Are there really no aftermarket sources for Bentley specific parts?
Old 09-16-2020 | 11:58 AM
Tony Cocks's Avatar
Tony Cocks is infamous around these parts
This may/may not be of use to you , the company being in the UK , but they do have a very high reputation here.
May be worth a call .
https://www.flyingspares.com/?gclid=CjwKCAjw74b7BRA_EiwAF8yHFGzzwJtSBJ_VZG_w6FZ 9c39x5qWMMosgApsvEffdAnxBAek43oQl0RoCfHcQAvD_BwE
Old 09-17-2020 | 08:06 AM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
There are interchangeable parts with the VW or Audi brand but aftermarket....Few and far between. I would personally stay away from any aftermarket anything for these cars. They are very temperamental and most things are a pain in the butt to change. If any OEM parts are here in the states the price is jacked up (in my experience) so I just bite the bullet and buy either from Flying Spares or Scuderia.
When I redid my front end I ordered from Rock Auto and the parts either had a TRW/Moog (or something like that) which is what I gathered Is standard parts most car manufacturers uses anyway.
Edit: I concur with British, check with Johnny also for parts before you buy elsewhere.
Old 09-17-2020 | 11:18 AM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
Flying Spares or Scudera, or Ebay. There isn't a comprehensive Audi/Bentley cross-reference, but if you spend some time digging around this board, you'll find good references.
I have a pdf document with lots of details some useful most just interesting. If you PM me your email address, I'll send it to you, it has some cross-references.
Is there anything in particular you're looking for? I've found that my independent knows a lot of part substitutions. For the expendable stuff, like brakes, I would stick with stock, but there are some threads on here from guys that found cheap replacements. The air struts: same thing, some of the aftermarket stuff gives guys fits, but some make it work.
Instead of aftermarket, you really want "gently used" for some items, Johnny has stuff as well as the guy in Florida that makes interesting videos as he takes apart GTs for salvage.
Old 09-17-2020 | 01:12 PM
LarrysFlyingSpur's Avatar
LarrysFlyingSpur is infamous around these parts
I find having the part number is the starting point to shopping for parts. For example, 3W0129620C, is the air filters. If you google/bing that part number you'll find them available from china(ebay) for $25 or from Bentley usa for $245 and every price in between. Does Bentley buy them from china then stick them in a Bentley box then charge an extra $200. for the box? I don't think so, but I don't know!
Another method is to "search this forum" for the part number and many times you'll find an alternate part number in someone's post. For example, a shifter dust cover, part # 3W1713111K can cost over $200, but searching the forum will surface an alternate part for much less.
For me, the last resort would be from Bentley or one of the other OEM part houses, they're priciest.
Old 09-18-2020 | 08:38 AM
silvertonesx24's Avatar
silvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud of
When I changed my air filters, I pulled the part and it had a VW part number on it that I used to find OEM filters without the Bentley upcharge.
Old 09-18-2020 | 09:31 AM
Originally Posted by Dark Green
The air filters for a W12 are Bentley specific, hence have a "3W" prefix, so are you referring to pollen filters, or to air filters for a V8, I wonder?
Pretty sure it was the engine air filters, W12, the old ones had a VW logo on it and part number. I'll have to search though prior pictures to find the one I took.
Old 09-18-2020 | 11:56 AM
https://www.flyingspares.com/?gclid=...RoCfHcQAvD_BwE
Old 09-18-2020 | 12:13 PM
This was helpful...thanks
Never thought parts would be so hard to find
Old 09-19-2020 | 08:02 AM
British's Avatar
Never thought parts non-stupidly overpriced parts would be so hard to find
Fixed it for you. Parts are easy to find. But Bentley hits the "4X" button on the cash register. That's also why I don't take my car to the dealer, some of the horror stories of guys getting $28,000 engine-out estimates (my independent charges $6,300) make me too shy to fight them.
Old 09-21-2020 | 04:44 PM
H-M3's Avatar
H-M3 is infamous around these parts
Although I'm in the UK, I prefer to use Autodoc in Germany.
They're a bit slow to deliver (generally a week from DE to UK), but they have the advantage of being well connected into VW/Audi's OEM supply chain, hence you can search their site using Bentley part numbers. Thus a copy of the Bentley Illustrated Parts Catalogue is essential.
For example: the part number given in the post above for an air filter is £42 from Autodoc for a Mahle part which is an OEM part made in Europe.
When I wanted front suspension arms they supplied the whole lot i.e. upper and lower, front and rear, and ARB links for £850 which is roughly $1000. That is for Lemforder which are OEM with the four rings ground off.
Compare that to Scuderia and Flying Spares who wanted almost £1200 for the same parts!
I know that Autodoc will deliver to the US, but the cost will be prohibitive for small orders.
hi mate you wouldn’t have the part numbers to hand would you? As I need to change the front on my one too.
cheers
Old 09-22-2020 | 06:12 AM
Yoghurtshotgun's Avatar
Yoghurtshotgun is infamous around these parts
What parts are you looking for I have a supplier that I can get parts from I can ask and get you a price much cheaper than skuderia or flying spares
Old 09-22-2020 | 06:14 AM
The only part I'm struggling to find is wing mirror glass for 2004 models anyone have any ideas? I've literally searched the world and can't find them
Old 09-22-2020 | 05:18 PM
British's Avatar
There are a whole bunch of them on Ebay.
Expensive as hell, but it's not like they're unobtainium.
https://www.ebay.com/itm/Bentley-Gtc...oAAOSwB9JZcUJA
Quick Reply: Aftermarket parts?
