View Poll Results: No need for poll
Yes
0%
No
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Bentley Continental Flying Spur 2005
Hy I have a Bentley Continental flying Spur 2005 LHD and my radiators fan stop working
the car was sitting for 2 months
I change the fans but still don’t work
i check the fuse box under the bonnet
and was full off water
o remove the water I dry all
and check all the fuse and relay but still don’t work
thanks
thanks
Have you ever cleaned the scuttle drain ?
The lid on that fuse box is a fiddle to seat back correctly, I bet many fail to re seat it correctly.
I made a extra cover for mine which keeps it dry , prevents the top getting wet ......incase the seal integrity fails .
If that’s gotten wet then there’s probably some loom damage / corrosion as a result of water left sitting about .
In my view parking theses outside in the weather is playing Russian roulette with the scuttle drains .A lot do I know .
search “ drain maintenance “ on here .
Here see the fuse box cover cover ,
https://www.6speedonline.com/forums/...enance-gt.html
Yes I dry I check all seems ok
I removed the cover for the relays and
I check them
1 on them “100” when I press manual is working but then is cut off
this happened when the car is start and a/c is on
I check them
was also weet on the passenger foot
but I find the problem was
on the fuse box under the bonnet
was a wire from relay 167 to 100 was not good I fix now works both radiator fans and no more engine light on the dash
i put all back now I putt some silicone on the fuse box also some double tape just in case water don’t go there
thanks anyway for your help
Last edited by Johnny Hotspur GT; 12-05-2020 at 10:41 AM. Reason: Fix quoted statement
