Power steering squealing
Old 01-07-2021 | 05:43 PM
J C's Avatar
J C
J C is infamous around these parts
I had a power steering squeal in my 2000 Bentley Arnage. I checked the level and added about 1/2 quart of Pentosin CHF11S up to the bottom of the screen. Now the steering is very noisy, jerky and hard to turn. Is there a way to bleed it? What is the proper procedure to add fluid? Thanks.
Old 01-07-2021 | 06:49 PM
Johnny Hotspur GT's Avatar
Administrator
Hello @J C ,
Does the Arnage not have a dip stick on the power steering fluid reservoir, being a half of a quart low is a lot, any leaks, anything on the ground after you added it, it will take quite a few turns full lock left to right to get any air out of the system.
Johnny
Old 01-07-2021 | 08:14 PM
J C's Avatar
J C
Hello @J C ,
Johnny
hi Johnny,
Thank you for the reply. There are no stains on the garage floor. There is no dipstick that I can find. There is a screen in the reservoir and the fluid should be visible at the bottom of the screen. Would I bleed it with the cap on the reservoir or off? It was better before I added fluid.
Old 01-09-2021 | 10:18 PM
Administrator
Originally Posted by J C
hi Johnny,
​​​@J C ,
Sorry I missed your response, you would leave the cap on, also, did you verify that you purchased the proper fluid for your 2000 Arnage ?
Johnny
Old 01-10-2021 | 05:58 AM
J C's Avatar
J C
​​​@J C ,
Johnny
Thank you. I have the chf 11s fluid that’s indicated on the cap. I will give it a try today.thanks for the advice. I was able to bleed it today like you said. Problem solved! Thanks again!!
Old 01-12-2021 | 05:51 AM
Administrator
Glad to help !
I would have the belly pan dropped to check for any leaks, as a half of a quart is a bit much depending on time frame between adding fluid.
Johnny
997TurboTom
08-28-2018 01:48 PM
ross_macdonald
Cayenne 955/957
04-01-2014 08:33 PM
ek1
Bentley
09-21-2013 06:43 PM
Stromangus
12-16-2012 11:33 PM
Quick Reply: Power steering squealing
