Bentley 2005 tpms issues
Old 03-21-2021 | 02:11 PM
Martin Golding's Avatar
Martin Golding is infamous around these parts
Hello, I am having the usual issues with the TPMS module, so bought a new one but I still cant get it to work. Everything on the Ross Tech (laptop) reads ok but it wont learn the settings on the infotainment display screen. I am now thinking that my stored pressure setpoints might be wrong, it is set at 2.8bar on the rear and 3.0bar on the front. I thought that as long as the tyre pressures were actually set to the same as the TPMS setpoints that it would work but I am now thinking this may not be correct. Can someone please let me know what the factory setpoints are for the front and back so I can reset the system to these and then inflate the tyres accordingly. I have spent so much time and money trying to get these things to work I am not giving up without a fight.
Old 03-23-2021 | 05:14 PM
sspeeder's Avatar
sspeeder is infamous around these parts
Mine is a 2005 model and I struggled for a long time with TPMS issues, which in the end could only be solved by replacing the module to the one part no. 3D0 907 273 G .If yours isn't this one don't waste any more time because with the older modules, as soon as you start having troubles you won't be able to get it to perform acceptably for any reasonable period of time.
After installation you should properly code the new module.
Then inflate tires to the recommended pressure (according to the owner's manual).
Go for a 20 minute ride on a stretch of road where you can roll at speeds around 100 km/h (starting with cold tires)
Use you headunit to start the learning sequence as soon as you start the ride.
Wait until the MIL goes out (it shouldn't take more the 15 minutes).
Up until I changed to this suffix lettered G module, I spent uncountable number of hours experimenting all sorts of modules coding, tire pressures, sensors replacements etc, all at no avail. Nothing seemed to work reliably when using the other suffix lettered modules.
All has been well and no more issues on the last 2 years with this newer module.
By the way, I run 2.9 bars front and 2,5 bars rear. I never drive at speeds that justify higher tire pressures.
Old 03-23-2021 | 05:31 PM
H-M3's Avatar
H-M3 is infamous around these parts
Thumbs up
I will follow this thread as I am having same issue.
Old 03-24-2021 | 01:21 PM
I agree, anything before a G is a waste of time trying to get working, and unless you have VAG COM you wont be able to fix it anyway as the new module needs to be coded to the car.
The problem I have is that I can drive around with my pc connected to the OBD and see everything working (temps, pressures etc) on all 4 wheels.
However it wont send all that info to the display on the car, and I just cant work out why. I think that if the pressures are not within 0.2 bar of the setpoint it will refuse to allow the system to work, but I really getting to the end of the line with this as it has taken months to get this far.
Old 03-24-2021 | 02:29 PM
sspeeder's Avatar
Hi Martin.
So I guess you are running with the G module.
Can you give me more info.
- What model and year is your Bentley?
- Is it an US model?
- what is the code you dialed in to the module?
- Have you run the learning procedure many times? If so, what was the results?
- Have you tried with different tire pressures? try lowering the rear tires pressure to, say, 2,5 bars.
this TPMS system is really very cumbersome, I think the newer models have more elaborated and reliable systems.
Old 03-29-2021 | 01:42 PM
I bought a new G ECU which is located next to the rear seat and replaced it.
To code it you need to connect the car to ross tech (vag com) or something similar.
Once the unit has been accepted it should just start learning and work after about 10-15mins drive however after many attempts this did not happen.
I have now set all the tyres pressures to 3bar and am now adjusting the setpoint values up and down to see if anything works.
So for example I set all the display setpoints to 2.8 bar, go for a drive (doesn't work) so I try setting them to say 3.2bar, go for a drive still doesn't work.
The code to change the setpoints (adaptation) for the TPMS module is 10896
The annoying thing is I can see the sensors are working, as they can be displayed on my laptop.
I will put a video on youtube next week and add a link.
Old 03-29-2021 | 02:34 PM
sspeeder's Avatar
Hi Martin.
Yes, to code the module you must connect your Bentley to Ross Tech VCDS or something similar. Here I am posting a picture as an example of the screen showing you the TPMS window in VCDS highlighting the the software code.
The correct code takes in consideration the car model, country market, with or without a spare wheel TPMS sensor, etc.
My car is a Bentley Continental GT, european model, without spare wheel sensor. The software code that works in my TPMS module is 0310354. (And not the one showing in the picture below)
If yours matches mine I am sure you can successfully use the same.
I hope this info helps you.
Old 03-30-2021 | 11:57 AM
Linescreamer's Avatar
Linescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud ofLinescreamer has much to be proud of
I think this whole concept is crazy. They should never put these things in cars and save all this time and money. One of the worst so called improvements in the automotive industry.
Old 05-20-2021 | 03:01 PM
tpms
Hi thanks Sspeeder I will try that code and see if it works, as I did notice the new ecu included a spare tyre sensor which my car does not have.
Once the weather improves i will let you know.
Old 09-30-2021 | 02:33 PM
molphar's Avatar
molphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud of
@Martin Golding @sspeeder
Can you tell me what exactly sensors you are using with
3D0907273G
Old 09-30-2021 | 03:55 PM
sspeeder's Avatar
Hi Martin,
Here is a link to the sensors I have bought 3 years ago. They are programable, I also bought a programable pad and all worked flawlessly. Never had any more issues with the TPMS.
Amazon Amazon
Kind regards
Old 09-30-2021 | 04:05 PM
molphar's Avatar
Sorry for boithering, what does it mean programable and what is pad?
upd like this?
Amazon Amazon
Old 09-30-2021 | 05:10 PM
sspeeder's Avatar
Yes, you can program the sensors with that tool. I bought a cheaper/simpler one that is just a pad, this one https://www.autelstore.co.uk/wholesa...ry-device.html
A programable sensor is one that can be cloned with the same ID as the one you have in the wheel presently either by inputting the ID manually or bridging it from the old one to the new one using that tool or the pad.
The pad has to be phisicaly connect to a PC via USB whereas that tool connects to the sensors wirelessly, thus way easier but a bit more expensive.
Good luck.
Old 10-01-2021 | 08:04 AM
molphar's Avatar
Thank you! I have no sensors at his time so as i understand i'll do it with vsds...
Old 10-30-2021 | 10:07 PM
molphar's Avatar
G module says 014 error
273 module is forever lerning. crap. useless annoying system(
lilo1980
Bentley
10
10-30-2021 10:00 PM
BWings
Bentley
03-11-2018 01:11 PM
steve.2.lowe
Bentley
11-04-2017 03:50 AM
csasfai
Merchandise For Sale / Wanted
01-28-2016 06:56 PM
REDNOSEGT
Bentley
05-20-2013 12:16 AM
Quick Reply: Bentley 2005 tpms issues
