Front parking Aid warning Buzzer H22
2012 Continental Gt rear camara NOT working , code (Front Parking Aid Warning Buzzer -H22 ) any Help to locate this h22 Please . I just buy the Buzzer H22 but need location . Thank you
Hello @ReyNODARSE ,
Being that you have a 2012 GT, I believe that you do have the two separate front and rear buzzers, apposed to the 2004-10/11 GT's that used 4 of the speakers in the audio system for the beep/tone.
So, if the 2012 GT is like the 2006 and up Flying Spur, and my 2005 Audi A8L W12, the front H22 buzzer is located behind the Instrument cluster.
Johnny
Johnny
Hello thanks for your help . we open the cluster and not found the h22 buzzer other diagram show in the center of dash if you can help me locate this h22 buzzer I will appreciate,
Thank You Rey
Thank You Rey
You say you "open the cluster", the h22 is not inside the cluster, it would be mounted to the dash behind the cluster, or in that general vicinity.
This is where the A8L has it mounted.
Johnny
Hello
I take out the cluster and not find the buzzers some diagram shoing in the center of the dash
When I put reverse I hear a buzzer noise in the driver sides quarter panel but i need to know where is locate the one in the front , but is not behind of the cluster i remove my cluster and is not there some of the diagram show in the center of the dash
exoticschaser
Bentley
03-15-2020 02:25 AM
